Gearbox Oil
Posted: Mon Oct 05, 2009 7:45 am
by rexx
Hi Everybody,
I would like some info on what oil i should be using in my gearbox ,transfer case and diff for my 01 hilux kzte Dc 4x4. Currently i am battling to shift into 1st and 2nd when cold.
Re: Gearbox Oil
Posted: Mon Oct 05, 2009 9:02 am
by Hoppy
The best for the gearbox: Castrol BOT 130, a bit expensive, or Shell spirax 80w90
Transfer box: Shell Spirax 80w90
Diff's: Shell spirax 85w140
Re: Gearbox Oil
Posted: Mon Oct 05, 2009 10:17 am
by rexx
Thanks, I can get Bot 130 for R50/500ml. Any idea of how much i will need to do the gearbox and transfer case.
Re: Gearbox Oil
Posted: Mon Oct 05, 2009 10:26 am
by Evert Deyzel
Hoppy
Maak dit saak of dit gl 4 of gl 5 is?
Ek het gehoor mens moet nie gl5 in die ratkas gooi nie, maar moet gl5 in die transfercase en diffs gooi....
Wat is jou opinie hieroor?
Dankie
Evert
Re: Gearbox Oil
Posted: Mon Oct 05, 2009 11:03 am
by GTO
GL 4 for gearboxes
Gl 5 for diffs
See here:
viewtopic.php?f=3&t=3232&hilit=gl5
Re: Gearbox Oil
Posted: Mon Oct 05, 2009 12:41 pm
by Mountain Man
Don't forget to get a price from Toyota because for my SFA they were R10.00 per 500Ml cheaper the from enywhere else. I don't know if that is the case with the KZTE.
Re: Gearbox Oil
Posted: Mon Oct 05, 2009 8:04 pm
by Sifu-Lux
Oh crap. I see now the mechanic that changed to gearbox oil seals refilled it with
Castrol EPX 80W90 GL5
Another 200 bucks down the recycling company.
Is GL 5 OK for the Transfer case, or must I drain this as well?
Re: Gearbox Oil
Posted: Mon Oct 05, 2009 10:38 pm
by Sifu-Lux
Went and checked the owners manual - Toyota specifies GL5 for the gearbox (G52 4x4 5 speed) and diffs
Now I feel better :D
Re: Gearbox Oil
Posted: Tue Oct 06, 2009 6:39 am
by Bloues
Thanks for info - but is it now ....??????? Which one do I buy and fill it up with ??????
Re: Gearbox Oil
Posted: Tue Oct 06, 2009 8:19 pm
by Sifu-Lux
SFA lubricant spec in owners manual:
download/file.php?id=545&mode=view
from a 1995 2.4 P SFA with Gearmax rear axle
Re: Gearbox Oil
Posted: Wed Jul 26, 2017 8:00 am
by Stef
I'll have to look in my hilux's manual...I also have it as 80W90 GL4 for the gearbox & txfer...
EP or EPX 90 GL5 front diff & 85W140 rear
I used Castrol which is a brown oil; I see Mayfair put a red oil into the box after replacing the cluster
