Overhauling the Rear Brake Cylinder - SFA Import (YN65)
I found that I had a major hydraulic fluid leak after this weekend's Trail must have been lead footed SWAMBO , looking at the fluid sprayed on the inside of the rear right tyre; it was the evidently the Rear Right Brake Cylinder Seals. :roll:
The answer - to strip and install a Seals Kit; Moto or Euro Parts Code: P 832 (Generic)
The procedure was pretty straight forward, I tried to document it well (with peekchaz Eric ) given that I didn't do peekchaz when I replaced the shoes last month. (hope this makes up for it :shifty: ) :roll:
The peekchaz are split over two post, please note the Title of the peekchaz to see what I'm trying to describe
Last edited by Dadz Toy BFI on Tue Aug 11, 2009 10:12 pm, edited 6 times in total.
Re: Overhauling the Rear Brake Cylinder - SFA Import (YN65)
Part II
Installation of New Seals and Re-assembly of Brake Shoes, tensioner, springs etc.....
Tools Used:
1. Long Nose pliers - essential for holiding shoe retaining clips, tensioning springs, removing pencil spring etc...
2. Flat Scredriver - in assisting long nose and levering springs and shoes into position, adjusting tensioner etc..
3. 10mm Open Ended Spanner - to open bleed screw
4. paint brush - for cleaning
5. Clean Green - more enviro friendly and less caustic than engine degreaser
6. Paint tray - for catching dirty cleaning fluid/haudraulic fluid etc.. and soaking parts
7. Symphoming device- consisting of 5mm clear tube attached to brake line submerged in tin od spent fluid
8. Silicone Spray - for seating new seals and coating internal springs after assembly
9. Replacement Dot4 Hydraulic Fluid (500ml)
10. Cat (Optional)
Time taken: Approx 1 and 1/2 hrs per wheel.
10. Cat (Optional)
Last edited by Dadz Toy BFI on Tue Aug 11, 2009 10:17 pm, edited 2 times in total.
Did you hone the cylinder a little befor installing the new kit?
Only the bore which is rear most; as it is downward facing it attracts the most corrosion;Mud Dog wrote:Did you hone the cylinder a little before installing the new kit?
see the tarnishing on the piston in the pick
required the lightest touch with 1200 grade wet and dry mos
Ironically it was the upward facing bore that had blown its seal
The downward facing (rear most) bore and piston was very very sticky, I'm sure that it wasn't functioning properly
Incredible what damage a few shallow water crossings and a bit of sand duning does to the rear brakes nê :x
Te luigat om 'n honer te koop nê!!
haven't needed one thus far AndyMud Dog wrote:Te luigat om 'n honer te koop nê!!
Just pulling the p!ss, fellow Soutie
Rich just a quick question. Why does it appear that the brake shoe has some oil on them. Hopefully my eyes is deceiving me and that it is just water or gleen green (yellow)?
- Scooter
- Town: JHB
- Real Name: Scott
Just a suggestion, for most vehicles you can buy complete rear cylinders relatively cheap (obviously not as cheap as a seal kit) but still cost effective.
This saves time, mess and fuss and enables the beginner DIYer to do the same job without having to worry about whether he/she has honed the cylinder correctly.
In the photo the shoes are still wet after washing with Clean Green and water :arrow:CasKru wrote:Rich just a quick question. Why does it appear that the brake shoe has some oil on them. Hopefully my eyes is deceiving me and that it is just water or gleen green (yellow)?
and
Yes, Clean Green is now available YELLOW (lemon Fragrance) :roll:
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Nice Rich
What shocks do you have.Never seen red ones
I think I will sway this way.Just a suggestion, for most vehicles you can buy complete rear cylinders relatively cheap (obviously not as cheap as a seal kit) but still cost effective.
Red Shocks! ... of course!george wrote:What shocks do you have.Never seen red ones
Yep I'd be keen to find out if these are available for the YN65 (Import Diff), where can you find these beasties and how much pleasescooter wrote: Just a suggestion, for most vehicles you can buy complete rear cylinders relatively cheap (obviously not as cheap as a seal kit) but still cost effective.
They are Original Toyota Gas Shocksgeorge wrote: What shocks do you have.Never seen red ones
Perfect fit on SFA's with a 50-60mm lift
They come Black and a bit scratched, painted mine up with hi-temp spray paint; paint was available in Primary Colours Only, Anything BUT Canary Yellow nê
They are 100% better than the Oil Cooled Gabriels I had on previously.
- Scooter
- Town: JHB
- Real Name: Scott
Just spoke with Gemini,a nd they tell me they have the complete cylinders @ R150 (+vat) each. (ex Japan)
For interest sake, new drums go for R285 each and new shoes for R350 per set.
My luxs drums need a overhaul but I wll be giving them a skim first with over size shoes. The next time they need it I will replace the drums. Called an old place I used to use when I was a mechy and the cost to skim and supply new shoes is R250 (stripping myself) or R470 with them stripping.
B & C Brake and Clutch
011 473 2388
1 Motor City
Main Reef road
Industria
011 473 2388
1 Motor City
Main Reef road
Industria
Scooter wrote:Just spoke with Gemini,a nd they tell me they have the complete cylinders @ R150 (+vat) each. (ex Japan)
011 473 2388
1 Motor City
Main Reef road
Industria
Very Useful Info Scott
Thanks for Posting
Ps... any chance of getting a price for Front Caliper Pistons please - they seem to corrode very quickly
- Sifu-Lux
- Town: Mount Vernon Illinois
- Real Name: Andrew
Nice write up Rich
Here's the contact details
GEMINI PARTS
16 Kruis Street
Marshall Town
JOHANNESBURG
Postal Address P.O.BOX 261048
EXCOM
Tel no 011 334 1417
Fax no 011 334 0069
e-Mail geminiparts@iafrica.com
So far quite impressed with the quality they supply at a good price
GEMINI PARTS
16 Kruis Street
Marshall Town
JOHANNESBURG
EXCOM
Tel no 011 334 1417
Fax no 011 334 0069
Sifu-Lux....I will miss you
Sifu-Lux wrote:Nice write up Rich
GEMINI PARTS
16 Kruis Street
Marshall Town
JOHANNESBURG
EXCOM
Tel no 011 334 1417
Fax no 011 334 0069
Yes have heard only good things about their Service and Generic Parts
Thanks Andrew
- Scooter
- Town: JHB
- Real Name: Scott
For those interested:
Front caliper pistons -
34mm - R170 each excl vat
43mm - R350 each excl vat
Scooter wrote:For those interested:
Scott - your a Legend Bro
R
