Is this the way it should be??
falcon
Town: Alberton
Vehicle: HILUX S/C 4X4
Real Name: Riaan
Post by falcon »
I have a 2009 S/C 3.0 D4D 4X4 and had 2 Pajero's before this one also 4X4 but the Hilux do something the others did not.When I drive in 4X4 High Range and turn into a corner at low speed like when I want to park it is jumping as if the Diff Lock is on and it is not it also feels like the hand brake is on because if I leave the petrol pedal it just stops this is strange.
Is this correct or is something else wrong?
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Re: Is this the way it should be??
Post by Mr_B »
Check that your rear drum brakes are not binding...
B
SuidWes
Town: Durbanville
Vehicle: Prado 120 VX
Real Name: Jaco
Club VHF Licence: B35
Post by SuidWes »
This will happen on tar or any surface where traction is good as the center diff is locked when 4H or 4L is selected on the Hilux - Not good for the vehicle.
falcon
Town: Alberton
Real Name: Riaan
Post by falcon »
I use it in the rain because the back is so light and it tend to spin out should I rather not?
ThysdJ
Club VHF Licence: HC102
Post by ThysdJ »
falcon wrote:I use it in the rain because the back is so light and it tend to spin out should I rather not?
You put a while lot of strain on the drive train because of the fact that the front and rear axles get "locked" together when you engage 4wd. Unlike a permanent 4wd vehicle the Hilux does not have a center diff. :shock: :shock: :shock: :shock:
Optimus Prime
Town: Krp
Vehicle: Fortuner 4.0 v6
Real Name: Robert
Post by Optimus Prime »
Id say rather not ,this can become an expensive excersise.
"As long as power flows through any of my circuits ill 4x4."
ThysdJ
Post by ThysdJ »
DieBul wrote:Id say rather not ,this can become an expensive excersise.
Agreed, rather load something heavy (a sandbag) in the loadbin to weigh it down or drive with a lighter right foot. :twisted: :twisted: :twisted:
falcon
Town: Alberton
Real Name: Riaan
Post by falcon »
:thumbup: Thanks for the response I will just have to take the tar corners more carefully in future :)
ToyX4
Town: Ottosdal
Vehicle: Rocky's
Real Name: Riaan
Post by ToyX4 »
Riaan, jy moet nooit daai bakkie op teer, nat of droog, in 4x4 ry nie. Jy gaan hom breek! Die drivetrain gaan opwen, want die teer is nie glibberig/los genoeg sodat die bande kan gly nie. Gaan ry bietjie op grond in 4x4, draai skerp, dan hoor jy hoe gly daai bande.
Ek ry n 3.0TDCi Ford, en as dit reen, is ek maar rustig op die throttle.
Riaan, listen to the guys here ... in a turn the front wheels travel on a wider arc than the back which means that the distance travelled differs. If you engage 4x4 you're locking front and back wheels to drive at the same speed. In a straight line, no prob but in a turn ... axle windup! A loose surface is forgiving and the wheels slip easily enough, but on tar somethings going to have to give and if it's not the tyres, it'll be a diff that strips or a half-shaft that snaps. Either way it'll be an expensive repair.
Some vehicle manufacturers used to employ a LSD (limited slip diff) on the drive wheels to overcome wheel spin on pull off, and improve drive traction in the wet. It seems that this is not so popular anymore because of the extra cost, but I think the bigger engined BMW's still have it. LSD's are still available as aftermarket upgrades on most vehicles, unless you already have difflock ... don't think you can have a combination of both.
BenHur
Vehicle: '96 D/C Raider
Real Name: Bennie
Post by BenHur »
Riaan
If you selected 4HLC on the Pajero you would experience the same. Remember the Pajero is about the only 4wd vehicle that can be driben in 4wd and 2wd on tar. Normally vehicles with a centre diff does not have a 2wd option and vehicles with 2wd dont have a centre diff :wink:
Return to “Useful Articles”
