Front Brake Calipers Ratteling noise
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
For those that are driving the SFA with solid discs in the front and hearing a metallic ratteling noise and occasional clunk/ clapping when applying brakes.
Have a look (Take the front wheels off) and see if there is anti rattle springs that fits over the sliding pins off the brake pads.
Here is a picture taken from my Hilux
The part no for this OE part is : 04947 60060
IIRC the cost was approx R 70-00 incl vat for both sides. I keep a spare set in my "magic" box as they tend to get weak with age and the temperature and the just sometimes breaks when replacing the pads.
Take note that the brake pads does not come with these kits. These are to be ordered as they are most of the times not in stock.
Re: Front Brake Calipers Ratteling noise
Thanks John. Mine is doing exactly that and I was still going to investigate but was a bit lazy to do so.... now I can remain lazy
- JohanM
- Town: Meyerton
Glad to be of assistance!!!!! I will fit it for you too!!! For a Fee...........
Daai is gaaf van jou maar gelukkig is ekkie bang vir daai goete nie. Haal mos gereeld die pad tyres en rims af om plek te maak vir die Mud tyres en rims (het juis weer gister) en kan sommer dan terselfde tyd daai goete in sit.
Jy wil nie dalk by daai contact van jou (wink wink) uitvind wat is die part nommer vir bearings en seels vir die agter as nie? (local as) Ek dink myne is besig om te groet :evil:
- JohanM
- Town: Meyerton
Cassie, ek sal so maak vir jou!!! Kyk of ek dit gefaks kan kry, dan kan jy dit dalk scan (ek het nie `n scanner nie) en dit ok hier opsit.
- JohanM
- Town: Meyerton
Cassie, hIer is `n upclose van hoe die spring lyk voor hy gefit word.
Rattle Spring - Brake calipers:
R35 vir daai stukkie draad is darem maar baie
Nee Cassie jy het dit verkeerd dis R 2 vir die draad en R33 vir die skill om hom so te buigCasKru wrote:R35 vir daai stukkie draad is darem maar baie
Jy sien... Jy moet maar verskoon. Ek is uit die skool uit in std 6 tweede pouseBenHur wrote:Nee Cassie jy het dit verkeerd dis R 2 vir die draad en R33 vir die skill om hom so te buigCasKru wrote:R35 vir daai stukkie draad is darem maar baie
- Scooter
- Town: JHB
- Real Name: Scott
Johan, did one spring per side work or is two per side needed?
- JohanM
- Town: Meyerton
Scott, I actually ordered two sets thinking that it should fit both sliding pins.......... but in fact it only fits the lower sliding pin on the caliper, and it stops the noise.
I tried to fit both sets but the caliper is not big enough to fit two sets....
- Scooter
- Town: JHB
- Real Name: Scott
Ordered 4 from Toyota @ R56 per spring.
I will check if it needs all 4 and if not then I will also have 2 spare to keep in the spares box.
Tried Gemini, but it is only a stealer part.
- MOFASA
- Real Name: Johno
- Club VHF Licence: X119
JohanM wrote:For those that are driving the SFA with solid discs in the front and hearing a metallic ratteling noise and occasional clunk/ clapping when applying brakes.
IIRC the cost was approx R 70-00 incl vat for both sides..
Thanks a million for the part number it helped big time as lots of people dont know what you talking about........
Quick update.........
The kit for both wheels now costs R104.23 + vat......
But i just cant handle the RATTLE.....
I have ordered a kit from Basil at Carnival Toyota 011 306 8800
Very nice guy, good service so far now lets see how long the kit takes to get here......
[rimg=206x128]
[rimg=206x128]
