http://en.wikipedia.org/wiki/List_of_Toyota_engines
List of Toyota engines
Toyota Motor Corporation has produced a wide variety of automobile engines. The company follows a simple naming system for their modern engines:
1. The first numeric characters specify the engine block's generation
2. The next one or two letters specify the engine family
3. The suffix (separated by a dash) specifies the features of the engine:
Suffix Feature
A Valvetronic variable lift intake head
B Twin SU-style side-draft carburetors
C Carburated / California Emissions Controlled
D Twin Downdraft carburetors
E Electronic Fuel injection
F Economy narrow-angle DOHC
G Performance wide-angle DOHC
H High compression like 9.8:1 (example: 5E-FHE)
High pressure charged (example: 2L-THE)
I Single-point fuel injection
J Autochoke (Early models) or unknown pollution control
L Transverse
M Philippines' market (meaning unknown)
N CNG fuel
P LPG fuel
R Low Compression (For 87 and below octane fuel)
S Swirl intake (1980s)
SE Direct injection (1990s)
T Turbocharged
U With Catalytic converter Japan-spec emissions
V Common Rail Diesel Injection (D-4D)
X Atkinson cycle (typically also indicates a Hybrid engine, as Toyota only uses the Atkinson cycle with hybrids)
Z Supercharged
For Example
* 4A-GE
4 - 4th Generation Engine In The A Engine Family
A - The Engine Family it is in
G - Wide-angle dual camshaft
E - Electronically Fuel Injected
* 22R-TEC
22 - 22nd Generation Engine In The R Engine Family
R - The engine family it is in
T - Turbocharged
C - California Emission Controlled
Contents
[hide]
* 1 Flat-twin
* 2 Straight-3
* 3 Straight-4
* 4 Straight-6
* 5 V6
* 6 V8
* 7 V12
* 8 Diesel
* 9 External links
[edit] Flat-twin
* 1961 - U
o 1961-1966 - 697 cc U
o 1965-1969 - 790 cc 2U
o 1966-1976 - 790 cc 2U-B
[edit] Straight-3
* 2004 - KR - DOHC
o 2004 - 1.0 L (998 cc) 1KR
[edit] Straight-4
* 1953 - R - OHV/SOHC/DOHC
o 1953-1964 - 1.5 L (1453 cc) R
o 1964-1969 - 1.5 L (1490 cc) 2R
o 1959-1968 - 1.9 L (1897 cc) 3R
o 1965-1968 - 1.6 L (1587 cc) 4R
o 1968-1986 - 2.0 L (1994 cc) 5R
o 1969-1974 - 1.7 L (1707 cc) 6R
o 1968-1970 - 1.6 L (1591 cc) 7R
o 1968-1972 - 1.9 L (1858 cc) 8R
o 1967-1968 - 1.6 L (1587 cc) 9R
o 1969-1988 - 1.6 L (1587 cc) 12R
o 1974-1980 - 1.8 L (1808 cc) 16R
o 1971-1982 - 2.0 L (1968 cc) 18R
o 1975-1977 - 2.0 L (1968 cc) 19R
o 1974-1980 - 2.2 L (2189 cc) 20R
o 1978-1987 - 2.0 L (1972 cc) 21R
o 1980-1995 - 2.4 L (2366 cc) 22R
* 1959 - P
o 1959-1961 - 1.0 L (997 cc) P
o 1961-1972 - 1.2 L (1198 cc) 2P
o 1972-1979 - 1.3 L (1345 cc) 3P
* 1966 - K - OHV
o 1966-1969 - 1.1 L (1077 cc) K
o 1969-1988 - 1.0 L (993 cc) 2K
o 1969-1979 - 1.2 L (1166 cc) 3K
o 1978-1989 - 1.3 L (1290 cc) 4K
o 1983-1989 - 1.5 L (1496 cc) 5K
o 1998-1998 - 1.8 L (1781 cc) 7K
* 1970 - T - OHV/DOHC
o 1970-1979 - 1.4 L (1407 cc) T
o 1970-1985 - 1.6 L (1588 cc) 2T
o 1977-1985 - 1.8 L (1770 cc) 3T
o 1970-1983 - 1.6 L (1588 cc) 12T
o 1977-1982 - 1.8 L (1770 cc) 13T
* 1978 - A - SOHC/DOHC
o 1978-1979 - 1.5 L (1452 cc) 1A
o 1979-1986 - 1.3 L (1295 cc) 2A
o 1979-1988 - 1.5 L (1452 cc) 3A
o 1980-1998 - 1.6 L (1587 cc) 4A
o 1987-1998 - 1.5 L (1498 cc) 5A
o 1989-1992 - 1.4 L (1397 cc) 6A
o 1993-1998 - 1.8 L (1762 cc) 7A
* 1982 - S - SOHC/DOHC
o 1982-1988 - 1.8 L (1832 cc) 1S
o 1982-1987 - 2.0 L (1995 cc) 2S
o 1985-2005 - 2.0 L (1998 cc) 3S
o 1987-1998 - 1.8 L (1838 cc) 4S
o 1990-1995 - 2.2 L (2164 cc) 5S
* 1982 - Y
o 1982 - 1.6 L (1626 cc) 1Y
o 1982 - 1.8 L (1812 cc) 2Y
o 1982-1998 - 2.0 L (1998 cc) 3Y
o 1985-1993 - 2.2 L (2237 cc) 4Y
* 1985 - E - SOHC/DOHC
o 1985-1994 - 1.0 L (999 cc) 1E
o 1985-1998 - 1.3 L (1295 cc) 2E
o 1986-1994 - 1.5 L (1456 cc) 3E
o 1989-1998 - 1.3 L (1331 cc) 4E
o 1991-1998 - 1.5 L (1497 cc) 5E
* 1990 - TZ - DOHC
o 1990-1998 - 2.4 L (2438 cc) 2TZ
* 1997 - ZZ - DOHC
o 1997 - 1.8 L (1794 cc) 1ZZ
o 1999 - 1.8 L (1796 cc) 2ZZ
o 2000 - 1.6 L (1598 cc) 3ZZ
o 2000 - 1.4 L (1398 cc) 4ZZ
* 1998 - RZ - SOHC/DOHC
o 1998 - 2.0 L (1998 cc) 1RZ
o 1997 - 2.4 L (2400 cc) 2RZ
o 1997 - 2.7 L (2693 cc) 3RZ
* 1999 - SZ - DOHC (by Daihatsu)
o 1999 - 1 L (997 cc) 1SZ
o ? - 1.3 L (1298 cc) 2SZ
o 2006 - 1.5 L (1495 cc) 3SZ
* 1997 - NZ - DOHC
o 1997 - 1.5 L (1496 cc) 1NZ
o 1999 - 1.3 L (1298 cc) 2NZ
* 2000 - AZ - DOHC
o 2000 - 2.0 L (1998 cc) 1AZ
o 2000 - 2.4 L (2362 cc) 2AZ
* 2003 - TR - DOHC
o 2003 - 2.0 L (1998 cc) 1TR
o 2003 - 2.7 L (2694 cc) 2TR
* 2007 - ZR - DOHC
o 2007 - 1.6 L (1598 cc) 1ZR
o 2007 - 1.8 L (1797 cc) 2ZR
o 2007 - 2.0 L (1986 cc) 3ZR
[edit] Straight-6
* 1948 - F - OHV
o 1948-1975 - 3.9 L (3878 cc) F
o 1975-1987 - 4.2 L (4230 cc) 2F
o 1985-1992 - 4.0 L (3956 cc) 3F
* 1965 - M - SOHC/DOHC
o 1965-1985 - 2.0 L (1988 cc) M
o 1966-1972 - 2.3 L (2253 cc) 2M
o 1966-1971 - 2.0 L (1988 cc) 3M
o 1972-1980 - 2.6 L (2563 cc) 4M
o 1979-1988 - 2.8 L (2759 cc) 5M
o 1984-1987 - 3.0 L (2954 cc) 6M
o 1986-1992 - 3.0 L (2954 cc) 7M
* 1979 - G - SOHC/DOHC
o 1979 - 2.0 L (1988 cc) 1G
* 1993 - FZ - DOHC
o 1993- 4.5 L (4477 cc) 1FZ
* 1993 - JZ - DOHC
o 1990 - 2.5 L (2491 cc) 1JZ
o 1993 - 3.0 L (2997 cc) 2JZ
[edit] V6
* 1987 - VZ - DOHC
o 1987 - 2.0 L (1992 cc) 1VZ
o 1987-1991 - 2.5 L (2496 cc) 2VZ
o 1987-1997 - 3.0 L (2958 cc) 3VZ
o 1993-1998 - 2.5 L (2496 cc) 4VZ
o 1995-2004 - 3.4 L (3378 cc) 5VZ
* 1994 - MZ - DOHC
o 1994 - 3.0 L (2995 cc) 1MZ
o 1998 - 2.5 L (2496 cc) 2MZ
o 2003 - 3.3 L (3310 cc) 3MZ
* 2003 - GR - DOHC/VVT-i
o 2002 - 4.0 L (3955 cc) 1GR
o 2006 - 3.5 L (3456 cc) 2GR
o 2003 - 3.0 L (2994 cc) 3GR
o 2006 - 2.5 L (2499 cc) 4GR
[edit] V8
* 1963 - V - OHV
o 1963-1967 - 2.6 L (2599 cc) V
o 1967-1973 - 3.0 L (2981 cc) 3V
o 1973-1983 - 3.4 L (3376 cc) 4V
o 1983-1998 - 4.0 L (3995 cc) 5V
* 1989 - UZ - DOHC
o 1989 - 4.0 L (3969 cc) 1UZ
o 1998 - 4.7 L (4663 cc) 2UZ
o 2000 - 4.3 L (4300 cc) 3UZ
* 2006 - UR - DOHC/VVT-i
o 2006 - 4.6 L (4608 cc) 1UR
o 2007 - 5.7 L (5663 cc) 3UR
[edit] V12
* 1997 - GZ - DOHC
o 1997 - 5.0 L (4996 cc) 1GZ-FE
[edit] Diesel
* 1956- D
o 1956-??? 5.9 liter 1D
o 1962-??? 6.5 liter 2D
* 1967 - H - OHV
o ???-??? - 3.5 L (3576 cc) H
o 1980-1990 - 3.9 L (3980 cc) 2H
o 1986-1990 - 3.9 L (3980 cc) 12H
* 1974 - B - OHV/SOHC
o 1974-1980 - 2.9 L (2977 cc) B
o 1980-1982 - 3.1 L (3168 cc) 2B
o 1981-1990 - 3.4 L (3431 cc) 3B
o 1984-1990 - 3.4 L (3431 cc) 13B
o 1996-2002 - 4.1 L (4104 cc) 15B
* 1980 - L - SOHC
o 1980-200? - 2.4 L (2446 cc) 2L
o 1991-1997 - 2.8 L (2779 cc) 3L
o 19??-? - 3.0 L (2800? cc) 5L
* 1984 - C - SOHC
o 1984-1992 - 1.8 L (1839 cc) 1C
o 1984-2000 - 2.0 L (1974 cc) 2C
o 1994-2002 - 2.2 L (2184 cc) 3C
* 1986 - N - SOHC
o 1986-19?? - 1.4 L (1453 cc) 1N
* 1993 - KZ - SOHC
o 1993-? - 3.0 L (2982 cc) 1KZ
* 1990 - PZ - SOHC
o 1990-1994? - 3.5 L (3469 cc) 1PZ
* 1990 - HD - SOHC
o 1990-? 4.2 L (4164 cc) 1HD
* 1990 - HZ - SOHC
o 1990-? 4.2 L (4163 cc) 1HZ
* 2000 - CD - DOHC
o 2000-2006 2.0 L (1995 cc) 1CD-FTV
* 2001 - ND - DOHC
o 2001- 1.4 L (1364 cc) 1ND-TV
* 2001 - KD - DOHC
o 2001- 2.5 L (2494 cc) 2KD-FTV
o 2001- 3.0 L (2982 cc) 1KD-FTV
* 2005 - AD - DOHC
o 2005- 2.2 L (2231 cc) 2AD-FTV
o 2005- 2.2 L (2231 cc) 2AD-FHV
o 2006- 2.0 L (1998 cc) 1AD-FTV
