SFA window winders
Musselcracker
Vehicle: 1989 SFA D/C
SFA window winders
Post by Musselcracker »
Looking for working window winder mechnism for my front two windows in the 89 dc hilux?
:crazy: :crazy:
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Re: SFA window winders
Post by Mr_B »
Chris,
Most of the larger spares places will carry these... like Gemini... I think they are the same as the taxi ones... but you must check why the old ones gave up, usually the window seals(bottom and around the sides) are to blame... they get really dirty/worn on the inside and tend to make the window jam, of course you need my force to open/close the window... eventually this kills the winder mech... original Toyota replacement seals are hideously expensive... but you can DIY these from generic seals available at Rubber/Plastics retailers, this is what I did: viewtopic.php?f=41&t=8803&p=94598
Mr B
Musselcracker
Thanks OOM B
It may be the window seals, as the winder winds down and i have to push the window down or pull it up again.. the mechanism just feels very loose in the hand
I will check out your link now
Maddoglips
Town: P.E.
Vehicle: Raider 2.2 4x4; Mikem 50mm raised suspension, long range tank, Monroe gasses all round.
Real Name: Zane
Post by Maddoglips »
Chris
What you describe, sounds to me like the rails/sliders have come/rusted loose from the glass.
This would cause exactly what you are describing, they are as standard just placed in the rail with sika flex/silicone and thats why the winder feels so loose/free to move now that they've come free.
I would suggest opening the door panel and checking before buying anything, it could just be the above and then all it takes is a tube of Sika and your time.
Good luck.
Musselcracker
Hang on...
So your saying that the glass may have come loose in the slide that it rests in....
WIll definitely check that out... So then just lift the glass up and smeer some silicon in the rail and slide the glass down and let it set?
perfect
:drinks:
Maddoglips
Town: P.E.
Real Name: Zane
Chris
You've got it!
I would suggest using Sika Flex as normal silicone dont hold for long :thumbdown: ask me I know cause I tried and now have to do it again.
Take the door panel off,
Wind the mechanism down till you can see the slider, it bolts on with 2 bolts to the glass "holder"
If it has come loose on the glass, clean it up and put in the sika flex
Push the window down gently into it making sure it seats correctly,
wind the window up/closed put a small amount of pressure to ensure its seated and leave for 24hrs
This should do it.
Good luck and keep us informed of findings.
Maddoglips
Town: P.E.
Real Name: Zane
And the out come of the inspection is?????????????????????????????????????
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Maddoglips wrote:And the out come of the inspection is?????????????????????????????????????
Not known... :twisted:
Musselcracker
LAst night I wrestled with it
The window is seated firmly in the bracket... The winding mechanism seems to be loose...
The whole thing completely conked out on me last night with the window down... I took the winding mechnism out (Well i could not undo the slider thing at the bottom) but i fiddled as best i could and it just started working better than before. I suspect that it was not sitting probable on the door, thus winding scew and causing strain on the mechanism.
I tightened everything proper and WD 40 everything.. seems good!
I did mess up my central locking in the process.... are those little pump servo things pretty standard to replace?
Bosfebok
Town: Roodekrans
Vehicle: 1995 Hilux Raider 2.2
Real Name: Otto
Club VHF Licence: X248
Post by Bosfebok »
Any alarm place will be able to supply you with a central locking servo...they're quite cheap... Replaced all four of mine a while ago.. with fitting.. R550...
Otto X248
1995 Hilux Raider 2.2 EFI Turbo DC
Alucab Canopy with Kitchen and Recovery sections
National Luna Split Charge system and Dual Battery
80W solar panel and MPPT controller
20.5" LED BAR
5ton tow bar with recovery points
Nudge-M front bumper
80l Long Range Fuel Tank
90l Water Tank
Slide Drawer System
Safari Snorkel
Double Lockers - Toyota Electric selectable
Diff breathers
The worst anti hi-jack alarm system ever, SANJI!!
A bad day out is still better than a good day in!!
Return to “Useful Articles”
