Hi,
I gave my 2.4 P a mini-overhaul, but I didn't mark all the small pipes going to and fro between the carb and the black circular thingy against the body (b.t.w. what is that??)
Does anybody have a lay-out of all the pipes (there're so many), or can somebody perhaps take a few photies so that I can connect them correctly? I have connected them as far as I could remeber and everything seems fine (it's running!!), but I would like to make sure.
Help would be much appreciated.
Cheers,
C
2.4 P Carb Pipes
- cprinsloo
- Vehicle: 1998 D/C 4x4
- Club VHF Licence: X52
2.4 P Carb Pipes
1998 Hilux D/C Lexus VVTi
Re: 2.4 P Carb Pipes
The black thingy on the side... I believe is an altitude compensation thingy... changes the air fuel ratio based on altitude... but the 2.4 pipes I know nothing about(except that one of them is the vacuum advance pipe)... the 4Y's pipes drove me up the wall... so I decided to go EFi... so much less pipes!
B
B
- cprinsloo
As soon as Bennie can sort the supply problems..... :D :Dsnipes wrote:The black thingy on the side... I believe is an altitude compensation thingy... changes the air fuel ratio based on altitude... but the 2.4 pipes I know nothing about(except that one of them is the vacuum advance pipe)... the 4Y's pipes drove me up the wall... so I decided to go EFi... so much less pipes!
B
- Town: Durbanville
- Vehicle: Prado 120 VX
- Club VHF Licence: B35
Sal die help
- Werner
- Vehicle: 2009 Toyota Fortuner 3.0D 4x4
- Real Name: Werner
Hi,
PM my jou email adres....vir 1 of ander rede kan ek nie die fotos laai en wil dit nie kleiner maak nie, want dan kan jy nie die detail sien nie.
Werner
Werner
Werner Goosen
'94 80 Series Land Cruiser
I don't know.....I don't care.....I just don't
- cprinsloo
Dankie Werner, gedoen.Werner wrote:Hi,
Werner
- Werner
- Real Name: Werner
Chris,
Het vir jou die goed gemail.....hoop dit help.
Werner
Werner
Werner Goosen
