Load Hog helper spring
Niel
Real Name: Niel
Post by Niel »
I saw this product on the rear spring pack of a 94 SFA. Now
What is you opinion on this product? Will you fit it? and why
http://www.loadhog.co.za/
Some advantages:
Reduces Rear End Sag
• Reduces Body Roll
• Improved Handling And Stability, Loaded Or Unloaded
• More Responsive Suspension
• No More Bottoming Out
• Reduced Sway And Drift
• Improved Safety And Comfort for Occupants
• Smooth Stable Ride When Empty
• Reduced Tyre, Shock and Suspension Wear.
• Fitted In 20 Minutes.
ThysdJ
Club VHF Licence: HC102
Re: Load Hog helper spring
Post by ThysdJ »
If I remember correctly these "spring helpers" impede the articulation of the rear wheels Niel. They are great for carrying load on dirt roads, but not for off-road use. :twisted: :twisted:
ToyX4
Town: Ottosdal
Vehicle: Rocky's
Real Name: Riaan
Post by ToyX4 »
At the mall you don't really need exceptional articulation :twisted:
Dadz Toy BFI
Post by Dadz Toy BFI »
ToyX4 wrote:At the mall you don't really need exceptional articulation :twisted:
You haven't been shopping with Mrs.Vivier :o: :o:
Niel
Real Name: Niel
Post by Niel »
Het jy al Tygervallei se paaie gesien :roll: (bosvarkie se suspensie het nou nog n knou weg) ...dan sal jy n ander storie gesels :shock:
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Like Thys said, they are not suitable for heavy 4x4 terrain... but that's not what they are intended for, these devices are there to assist the rear suspension when carrying heavy loads(hence the name 'Load Hogs'), like overlanders do, they offer major assists when travelling at speed on highways as well as on gravel roads... I have seen a set fitted to an SFA, when deflated they don't hinder articulation... I wouldn't mind a set... but I am rather thinking along the lines of a small offroad trailer, to carry the bulk of the weight, instead of ladening the vehicle to heavily...
Niel I'm not entirely sure how they would cope with your weight... may need a heavier duty one on the drivers side... :twisted:
B
Niel
Real Name: Niel
Post by Niel »
snipes wrote:Niel I'm not entirely sure how they would cope with your weight... may need a heavier duty one on the drivers side...
Snip, you have a PMs :lol:
Ok ok. Britney. Will it not curve the spring pact and create a bit of a lift?
infanta
Post by infanta »
Soos jy jou hare curve, daai tiepe soort curve.
Spartan
Town: Vanderbijlpark
Vehicle: 98 LTD Hilux 4x4 SFA, 2JZ GE L6 VVT-i 3.0i, Bilstein shox, OME and a Land Cruiser 79 series
Real Name: Jaco
Post by Spartan »
Kaspaas wrote:They are great for carrying load
Ek het in 97 n stel op my tolla Van gehad wat 99% met n vrag geloop het en kon nie kla nie maar het nie off-road gedoen met die voertuig nie, vir vrag dra is hull 100% :thumbup: :thumbup:
MOBILITATE VINCERE
Spartan
Umvubu
Town: Lydenburg
Vehicle: Hilux D/C 4Y & Hilux S/C 2.4D & Musso 602EL
Real Name: Ezere Du Plessis
Post by Umvubu »
Nie so goed vir off-roading. Soos die manne sê, uitstekend vir wanneer jy vrag dra.
cprinsloo
Town: Nelspruit
Vehicle: 1998 D/C 4x4
Club VHF Licence: X52
Post by cprinsloo »
I have a pair on my SFA, but I carry a heavy load if I go overlanding. Definitely helps with the sag of the standard springs. They are relatively easy to adjust to suit the need.
Air springs apparently better, (I'm saving for mine :) )
The Load Hog springs tend to shift a little bit, but nothing major. They can interfere with the handbrake cable, I extended the handbrake levers a little bit.
Cheers,
CP
1998 Hilux D/C Lexus VVTi
GTO
Town: Fish Hoek
Vehicle: 2002 2700i 4x4 DC ; 1995 2.4 SRX
Real Name: Stephen
Post by GTO »
My brother bought a 2004 Legend 2700i 4x4 with lots of extras a few weeks ago.
One the extras is Firestone air suspension.
I suppose these would also effect articulation?
1985 Suzuki DR600S
1984 Honda ATC200ES BIG RED
