Rear brake drum getting very hot.
- Riceburner
- Town: JHB
- Vehicle: D2 V8
- Real Name: Darryl
I just installed new shoes in the rear, I adjusted them as normal, equally on both sides. My driver side gets very hot but I cant fell any binding when I turn it by hand. Driving me insane, the passender sides fine. WTH?
Re: Rear brake drum getting very hot.
How is your wheel bearing? It might be on it's way out and is causing the heat! Mine is due for a replacementRiceburner wrote:I just installed new shoes in the rear, I adjusted them as normal, equally on both sides. My driver side gets very hot but I cant fell any binding when I turn it by hand. Driving me insane, the passender sides fine. WTH?
- Riceburner
- Town: JHB
- Vehicle: D2 V8
- Real Name: Darryl
Bearings are 100%.
- Umvubu
- Town: Lydenburg
- Vehicle: Hilux D/C 4Y & Hilux S/C 2.4D & Musso 602EL
- Real Name: Ezere Du Plessis
Darryl, why don't you adjust the side that give you trouble a bit more. Had the same problem once or twice. Maybe when you brake the first time the shoes does'nt come all the way back , spring gets stuck or piston that pushes brake-shoes not working properly ?
- Riceburner
- Town: JHB
- Vehicle: D2 V8
- Real Name: Darryl
Loosen the one side?
- Umvubu
- Town: Lydenburg
Yes, that solved my problem. Not to much though. Had to adjust 3 times. First time to much, only the one rear wheel braked. 2nd time to few, brake drum got hot. 3rd time -PERFECT.Riceburner wrote:Loosen the one side?
- Bfreesani
- Town: Roodepoort
- Vehicle: Nissan Sani 2.7TD
- Real Name: David
Did you replace drums as well. Mine did that after I replaced drums and shoes, then they told me the shoes are design for used drums, not new.. Had to skim me new drums after the warped TWICE
Later....
David
Hillbilly
David
Hillbilly
There are only two possible causes, Brakes and bearings. If it's not the bearings (wheel should turn freely by hand without play ... not too stiff) then it's got to be brake related. The handbrake set up properly, not too tight?
- Town: Springs
- Vehicle: Hilux 2700i
- Club VHF Licence: HC262
If it is only one drum that is getting hot then it is not the handbrake.Loosen the brakes a bit and drive it for a 100km and then reset.The shoes must seat to the drums before you can set it properly.
- Riceburner
- Town: JHB
- Vehicle: D2 V8
- Real Name: Darryl
I normally drive through water, it makes the asbestos wear quicker so it seats faster. Brakes feel spongy though.
