Hilux 2005 V6 4.0 problem with gearbox
Phillip3000
Town: Biloela
Real Name: Phillip
Post by Phillip3000 »
Having problems with gearbox changes good around town n highway just under pressure like going up hills or overtaking like f it's in that gear for a bit it won't change from 4th to 5th straight away it takes like 5 to 6 seconds or more even with foot of power has 250.000 on clock just done a full gearbox service n still does it has been put on a scan but does not come up with any codes any help would be great thanks
Phillip3000
Town: Biloela
Real Name: Phillip
Re: Hilux 2005 V6 4.0 problem with gearbox
Phillip3000 wrote: Fri Jun 03, 2022 9:18 am Having problems with gearbox changes good around town n highway just under pressure like going up hills or overtaking like f it's in that gear for a bit it won't change from 4th to 5th straight away it takes like 5 to 6 seconds or more even when U lift foot of power won't change till about 5 too 6 seconds has 250.000 on clock just done a full gearbox service n still does it any help would be great thanks
Hilux 1
Real Name: Tertius
Club VHF Licence: HC137
Post by Hilux 1 »
following......
ahmedoo
Town: pre
Vehicle: toyota fortuner
Real Name: ahmed
Post by ahmedoo »
Having almost the same problem just did a recon on my box hopefully it gets sorted
Phillip3000
Town: Biloela
Real Name: Phillip
Is yours doing it before or after U recon the gearbox mate
ahmedoo
Town: pre
Real Name: ahmed
Post by ahmedoo »
Before the recon after the recon not much better it’s gone back in at the moment
Phillip3000
Town: Biloela
Real Name: Phillip
ahmedoo what's it doing mate can U explain thanks cheers
ahmedoo
Town: pre
Real Name: ahmed
Post by ahmedoo »
Mine will change up but not down unless I slow down a lot and at times on an uphill at higher revs it’s makes a time of a whistling noise
Since it’s back from the recon it won’t take gears in the morning when cold and second gear also hassling
Phillip3000
Town: Biloela
Real Name: Phillip
Ok thanks let me now how it goes mate
