I have a 2009 dual cab D4D, a couple of weeks ago I noticed a whistling/chittering noise coming from somewhere around the front left wheel, it only starts after the car has warmed up a bit and around 60kmh. It doesn't change pitch with speed, just remains constant. After getting the vehicle serviced the mechanics could not isolate the noise, as when up on the hoist, with no load, the noise doesn't manifest, its only while driving under normal road conditions. anyone have any idea what it could be. the vehicle is an auto.
Any help would be appreciated :)
high pitch whistle/chittering
- Baasvark
- Town: Virginia
- Real Name: Shane
Re: high pitch whistle/chittering
No idea really, but I would check wheel bearings just to be safe.
Sent from my SM-G998B using Tapatalk
- Town: Geraldton
- Vehicle: 2009 Hilux crew cab
- Real Name: Alan
Thanks for the input Baasvark, the wheel bearings have been checked out and deemed to be fine. I had the mechanic check them when I had the brakes and rotors serviced. I'm now thinking possibly diff bearings or seals, taking her to a different mechanic to get a fresh perspective. I appreciate your response mate, Cheers
- Baasvark
- Town: Virginia
- Real Name: Shane
Hope you get sorted. Please keep us updated
- Town: Geraldton
- Real Name: Alan
It ended up being the front transfer case seal, removed and replaced, problem finally solved. Happy Days.
