3.0 D4D 4X4 REAR BEARINGS & SEALS
Buff_87
Town: Johannesburg
Vehicle: Hilux 3.0D4D 07
Real Name: Bevan
Post by Buff_87 »
Hi all. New to the forum so hope I am not reapeating this question.
I have a hilux 3.0 D4D 4X4 07 model.
I have had an incessant squeak coming from the back.
It has been dignosed as the left rear axle bearings on the seal side.
I have been advised that it is neccessary to to replace the bearings, seals and drive shaft (Part no. 423110k040) as there is a issue with just doing the bearings and seals and they lie loose due to wear on the shafts and hence go again.
This problem is this then turns into a 30k job (to do left and right) as it includes the Shaft RR Axle at 14k for the two.
Anyone else experienced this?
Parts Estimate attached.
Parts Estimate
Parts Estimate
niclemaitre
Town: Stellenbosch
Vehicle: 99 IFS DC 4x4
Real Name: Nic
Re: 3.0 D4D 4X4 REAR BEARINGS & SEALS
Post by niclemaitre »
If the shaft has worn on the sealing surface it can be welded up and then turned down. I had this done on my SFA and it worked fine
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
