Hi All,
Any 2005–2015 SR5 manual Hilux out there with factory cruise control? I’m fitting cruise control to my 2010 manual KUN26R (non SR5) and the last piece of the puzzle is the clutch switch.
I believe it’s meant to go in place of the bolt circled in the photo below – can someone take a photo of theirs in the footwell – just follow the clutch pedal up, so I can see what it looks like?
I already bought the wrong switch (part #88280-42010 - too long, interferes with the spring above). It might be part #88280-14030 but I’d like to see what the factory one looks like before I order that one.
Thanks in advance!
Manual KUN26R Hilux cruise control - clutch switch
- Jaws
- Town: Sharonlea
- Vehicle: 2009 D4D 4x4
- Real Name: Herman
Re: Manual KUN26R Hilux cruise control - clutch switch
Sent from my ELE-L29 using Tapatalk
- Jaws
- Town: Sharonlea
- Real Name: Herman
You have the correct switch
You need a different mounting bracket
- Town: Perth
- Vehicle: KUN26R Hilux
- Real Name: Jono
In case it helps someone in the future, not wanting to replace the whole pedal assembly I bent up a bit of metal and mounted a microswitch to it. This works fine and seems to be the way aftermarket cruise control systems do it, so I don't think it will cause any problems.
- Jaws
- Town: Sharonlea
- Real Name: Herman
Nice work
- Town: halifax
- Vehicle: 2007 kun26L
- Real Name: Trent
Been installing cruise on my 07 kun26L manual non pre wired and need to know where the clutch switch plugs into on the wiring harness. Also it seems the way the truck sits now there is no voltage at pin 21
going to the cruise stalk. Not sure if this is normal with out the clutch switch in place.
Thank you
Thank you
- Town: Perth
- Real Name: Jono
Mine is right-hand drive, the clutch switch wiring was behind the vinyl lining of the footwell, taped to another harness:ttc wrote: ↑Mon Jan 02, 2023 1:27 pm Been installing cruise on my 07 kun26L manual non pre wired and need to know where the clutch switch plugs into on the wiring harness. Also it seems the way the truck sits now there is no voltage at pin 21
Thank you
This is it un-taped, showing the connector:
You might be out of luck though if there's no voltage on the E5-21 (CCS) pin, you should have 12v on that pin even without the clutch switch.
- Town: halifax
- Real Name: Trent
Thanks for the reply. The information seems to be a bit fragmented in the few threads I have read. But there seemed to be an idea that some ECM where not programmed for cruise. I may have to look at an aftermarket options
