2011 hilux d4d 4x4 brakes go into antilock in wet
- Town: melbourne
- Vehicle: 2011toyota sr hilux 4x4
- Real Name: Ges
Hi all just joined and thanks to the admins for allowing me to join. I have 2011 hilux sr 4x4 diesel and i have a problem with brakes in the wet they see to go into antilock mode where the car will just shutter and slide have replaced tyres from mud to a/t and still happens any suggestion would be appreciated
Re: 2011 hilux d4d 4x4 brakes go into antilock in wet
Welcome!
Easy fix - don't break so hard! In the wet you must be gentle on the brakes or the abs will be activated.
Also if you have oversize rims and tyres fitted it will influence braking negatively.
- Town: melbourne
- Real Name: Ges
thanks for the reply but this happens with very little pressure on brakes and previously had muddies was bad and changed to bridgestone duelers a/t on 15" rims and now running a/t on standard 16" rims can understand if braking hard the abs but seems that they come on most time and only in the wet
