2010 kun26 invincible broken front diff
Eau02467
Town: East kilbride
Vehicle: 2010 hilux dual cab
Real Name: Iain
Post by Eau02467 »
Hi guys, new to this forum and looking for a very simple answer - the front diff in my truck is broken and in the uk replacements are difficult / expensive to come by for a mk6. I can however get a mk7 front diff easily enough, the question is will it be a direct fit? They look to be the same and I believe the shafts etc are all the same between the mk6 and 7 so I can’t see any issue but thought I should check first
Re: 2010 kun26 invincible broken front diff
Hi Iain. I can't give you a definitive answer but in all probability they are the same. You could check with the agents in your area for confirmation that they are interchangeable. If they are, just be sure that the ratios are the same. :winkx:
