Hi Guys
I have an own MK2 Hilux from 1989 in South Africa, but myself I am in The Netherlands now and I would like to know what diameter the waterhoses (innersize) have that comes and goes to the engine.
Can you help me out?
Thanks in advance!
Marco Mok
Waterhose size
- Town: Middelburg
- Vehicle: Toyota Hilux & Prado
- Real Name: Monty
Re: Waterhose size
Hi Marco, Check under the manuals, perhaps there is a owner or maintenance manual for your vehicle? I worked on two later models the other day and the main coolant water pipe inside diameters were 40mm, in both cases.
Re: Waterhose size
Thanks Montie!
