Engine Oil in No.3 Spark Plug Well
Cheetah Drakie
Town: Nelspruit
Vehicle: Toyota Hilux 2.7i
Real Name: Peter
Post by Cheetah Drakie »
:shock:
Good day Hiluxers! Got the shock of my life when I pulled my plug leads to clean my Hilux 2700i tappet cover(3RZ-FE) !!
There was a considerable amount of oil in the No. 3 spark plug well. I understand the likely cause is the seals on tappet cover or O-rings on the spark plug wells?
Is this doable to do as DIY, or rather take to a workshop. The old girl is touching on 600 000 km
Hope to hear some input from the Hilux experts
Regards
Peter :surrender:
GTO
Town: Fish Hoek
Vehicle: 2002 2700i 4x4 DC ; 1995 2.4 SRX
Real Name: Stephen
Re: Engine Oil in No.3 Spark Plug Well
Post by GTO »
Yes very doable, did my 2700i about 2 years after also finding oil in No 3 plug well, each plug well has a round seal in the tappet cover.
I changed each seal as well as the tappet cover gasket.
While you have the tappet cover off check the valve clearance, on mine with half the mileage that yours has, I found on No 4 intake both valve clearance were slightly below the minimum clearance.
I had to order the correct shims from Toyota, you do need a special tool to remove the shims.
1985 Suzuki DR600S
1984 Honda ATC200ES BIG RED
GTO
Town: Fish Hoek
Real Name: Stephen
Post by GTO »
1985 Suzuki DR600S
GTO
Town: Fish Hoek
Real Name: Stephen
Post by GTO »
1985 Suzuki DR600S
GTO
Town: Fish Hoek
Real Name: Stephen
Post by GTO »
This video shows shims as well as valve cover gasket and plug seal replacement:
https://www.youtube.com/watch?v=FzrSAQJOugU
1985 Suzuki DR600S
Cheetah Drakie
Town: Nelspruit
Real Name: Peter
Much obliged! :thumbup:
Yes that would make sense to check, seeing the tappet cover is off.
