More.
Just a quick question:
Will the GD6 shape leaf springs fit on my 2010 Vigo (3.0 D4D Double Cab 4x4) shape? I see them advertised every now and then so just wondering about the possibility of a cheaper solution to my problem for now...
Need to replace them but cannot afford a new set right now...
Advice will be appreciated
Hilux Leaf springs
- Pumba
- Town: Durbanville
- Vehicle: Toyota Hilux 3.0 D4D 4x4
- Real Name: Kobus
- Club VHF Licence: HC112
Hilux Leaf springs
Jesus was blunt: "No chance at all if you think you can pull it off by yourself. Every chance in the world if you let God do it." Mark 10:27(Message)
Re: Hilux Leaf springs
As far as I could tell the undercarriage is identical. They take the same shock absorbers, brake components, shackles and so on. On the very latest model (released now) the leaf springs were lengthened to soften the ride. So I am fairly certain that the "older" model's leaf springs will fit.
- Pumba
- Town: Durbanville
- Real Name: Kobus
That sounds like good news, thanks.!
So must I look for a set up to 2019 model? Or do you know when they changed it?
- Tristin
- Town: East london
- Vehicle: Toyota hilux
- Real Name: Tristin
- Club VHF Licence: HC359
My father in law and I redid his GD6 leaf springs with a OME set from a D4D,the main and second blades on the GD6 are longer than the D4D.His hilux is a 2016 model GD6
