white smoke
- Town: traralgon
- Vehicle: 2007 hilux
- Real Name: ray
white smoke
Hi all ... got a 2007 hilux which had a water leak at the turbo inlet pipe ... had the turbo removed and the mechanic found that the pipe had a small crack in it .. replaced pipe , the leak has stopped now the puffs out white smoke out the exhaust and its using coolant ... any ideas
- ROOKIE
- Town: HILLCREST
- Vehicle: 12 4.0 V6 4x4.
- Real Name: PAUL
Re: white smoke
Hi Ray.
I would say you are getting coolant getting into combustion somewhere. Coolant burns with white smoke.
09 4.0 V6 Auto 4x4.
