Hi guys, hope you are well.
I've got a 2006 Hilux 3.0 D-4D 4x4.
It keeps going in limp mode when Im going over 140km/h (from 0 to 140km/h it runs good )and sometime when im overtaking, when the engine has been running for 40km + i need to switch off the engine for about 1min before it runs again, otherwise a simole off on, and it goes again
Ive done the following already and still keeps on going in limp mode :
Replaced the previous chip (which made it MUCH better as it was going in limp while driving in town at 30 -80Km/h ),
Ive replaced the following aswell : MAF sensor, turbo actuator/stepper motor, cleaned the EGR and throttle body, cleaned the intake, insuring flaps are working.
Disconnected the new chip, and still limp mode.
The engine also has a loudish grrrrrrrrrrr when going over 100, almost sound like a manifold leaking, but no leaks
Please help
3.0 d4d limp mode
- Town: Hermanus
- Vehicle: 06 Hilux 3.0 D-4D 4x4
- Real Name: Chatelle
Re: 3.0 d4d limp mode
Hi,
Perhaps time to have a diagnostic check?
- Jaws
- Town: Sharonlea
- Vehicle: 2009 D4D 4x4
- Real Name: Herman
You will have to read the error code to see what's causing the limp mode.
The cable is very cheap
#Aliexpress ZAR 251.14 13%OFF | Latest V14.20.019 MINI VCI Interface FOR TOYOTA TIS Techstream MINI-VCI FT232RL Chip J2534 OBD2 Diagnostic Cable Free Ship
https://a.aliexpress.com/_dVE9cvR
You can also find the required software on the Internet.
Just search for Toyota Techstream
Drive with a laptop and the cable plugged it
It will show you what's going on
Sent from my ELE-L29 using Tapatalk
- Town: Hermanus
The code it gives me , P2006
https://www.engine-codes.com/p2006_toyota.html
Check all vacuum lines first for leaks .... cracks or perishing.
