Temp Gauge: Works & then stops working
- Vehicle: 1998 2.8d 4x4 Toyota hilux sfa
- Real Name: Ryan
Hi everyone: I'm a newbie to owning a toyota Hilux, just got myself a 1998 2.8D double cab 4x4 sfa...my dream bakkie. I need some assistance pls, my temp gauge works and stops working for periods. Where and what must I look for? Has anybody else had this issue? From what I have read is that I should probably aim to fit a new digital temp gauge as the old gauges are not that accurate but I would still like to have the original one on the dash working. Thanks
Re: Temp Gauge: Works & then stops working
See if the wire on the temp sender unit makes good contact. Sometimes it is just poor contact which cause this.
- GTO
- Town: Fish Hoek
- Vehicle: 2002 2700i 4x4 DC ; 1995 2.4 SRX
- Real Name: Stephen
My 95 Hilux did exactly the same thing a few years ago, I found if I smacked the dash board it would work again.ryryarmstrong wrote: ↑Thu Mar 05, 2020 3:55 pm Hi everyone: I'm a newbie to owning a toyota Hilux, just got myself a 1998 2.8D double cab 4x4 sfa...my dream bakkie. I need some assistance pls, my temp gauge works and stops working for periods. Where and what must I look for? Has anybody else had this issue? From what I have read is that I should probably aim to fit a new digital temp gauge as the old gauges are not that accurate but I would still like to have the original one on the dash working. Thanks
I ended up buying a new one from Toyota, its an easy job to change it.
1985 Suzuki DR600S
1984 Honda ATC200ES BIG RED
1985 Suzuki DR600S
Sounds like a bad connection either at the sender as Pieter suggested or at the cluster itself, could also be a dry joint on the cluster board.
- GTO
- Town: Fish Hoek
Mine was the gauge itself, I checked all the connections/cleaned with electrical contact cleaner and put it back but it didn't improve until I changed the gauge.
1985 Suzuki DR600S
1985 Suzuki DR600S
