Good Evening Giuys,
I hope all well at your ends by the Grace of the Almighty.
I refer to the above subject matter.
I have come across another Isuzu 4JX1, and problem is, it gives out odour of Diesel when running, no leaks on the Fuel Lines, Fuel Filter, Tank & Primary Fuel Pump. No Diesel Leakage visible in the Engine Bay, but can smell Diesel when idling. Exhaust Gas seems to be richer in Diesel according to my inspection. I understand these engines use the Hydraulic Electronic Unit Injectors. Now with my inspection of Exhaust Gas being richer in Diesel Fuel, and no Diesel leaks seen, means that the Injectors are spraying excessive Diesel?
I understand that Isuzus 4JX1 uses Tech 2 Diagnosis equipment, am I right? Now how do i go about solving this issue?
Your assistance and co-operation on this will highly be appreciated.
N.B: I understand this forum discuses Hilux only, therefore, this maybe off topic?
Regards
Shermohamed
4JX1 Engines
- Town: Dar Es Salaam
- Real Name: Shermohamed
Re: 4JX1 Engines
Good evening to you all.
I hope all well at your end by the grace of the Almighty.
As per my research, I've come across the possiblity of having worn out Injector Sleeves, that cause the Diesel smell in the Engine Bay on the 4JX1 series, hence we will be removing the Injectors and the Sleeves once we've ordered the parts, as the Injector Sleeves for this engine aren't available in Tanzania.
Thought of sharing this with you.
Regards
Shermohamed
Regards
Shermohamed
