Greetings to one and all from a brand new member who has a 2013 Hilux Invincible with a hiccup and looking for a remedy.
The issue is that after having had the timing belt and pulley wheel changed at 150 000km it came back with engine running great except for one little distinguishable and intermittent loud metallic click. The intervals are about 3 to 5min while running and also once the engine is turned off there are 3 to 4 loud clicks over a period of +- 10min. Took it back to the dealer 3 times but they couldn't identify the type and location of the noise other than saying it could be the variable vanes sticking in the turbo. This is certainly plausible but before I go through the cost of checking something I was hoping someone might have had a similar situation and knowledge. On the off chance I was also wondering if the tensioner piston could be the issue?
I would upload a video clip but the attachment function does not support the file type i.e. MP4, AVI or WMV etc.
Loud Intermittent Click from engine
Re: Loud Intermittent Click from engine
Welcome Al
Your problem is a puzzling one and not one that I have heard of before this. (The turbo vanes sound like a possible cause.) Hopefully one of the guys here that are familiar with the diesel models can give some insight. Good luck.
- Real Name: Marnus
Noises from the engine are incredibly difficult to find if they are intermittent. The first question to pose is if you are certain that the noise was not there before changing the timing belt and if it is not a question of you noticing it now after the service now that you are listening to the engine more critically?
I suppose it is possible that the tensioner piston/damper could make aloud clicking noise but it would need to be worn to the extent that it has no damping/spring effect anymore. I think this is highly unlikely as I have replaced several and all of them were still fine after 150 000 kilometres. Even then it would make a noise while the engine is running but I cannot for the life of me see how that piston can make repeated mechanical clicks after the engine is turned off. It is however very easy to inspect the belt and tensioners as the cover is very easy to remove. The belt should be tight and there should be no movement at all on either the pulley or the piston if you attempt to move it by hand.
My thinking is leaning towards the turbo actuator or possibly the air conditioner pump although the clutch on the aircon pump cannot really make clicking noises if the engine is off and the ignition turned off.
- Town: Dublin
- Vehicle: Hilux Invincible 2013 model
- Real Name: al
Mars, thank you for taking the time to reply to my query. In looking for possible cause and remedy some youtube videos were showing the extensive build up of oil and carbon sludge around the turbo variable vanes which was causing the actuator to stick. I guess this means I have to consider a DIY job of getting at the turbo and reconditioning it myself as I imagine its a Big Bobs job if I take it back to the toyota mechanics.....
- Real Name: Marnus
It will probably be expensive yes. A DIY removal and clean-up of the turbo/actuator is really not that difficult. I hope you manage to get it sorted.
