SFA Powersteering Gearbox Oil
Tim86
Real Name: Tim
Post by Tim86 »
Hi Guys
Does the SFA powersteering gearbox take any oil?
In the manual it is evident that the non-powersteering box takes gear oil but nowhere does it mention the requirement of any gear oil for the powersteering box or the packing of grease during assembly, neither can I see any evidence of a filler plug on mine. Does the powersteering A/T fluid run through the entire box and lubricate it by any chance? Mine is as pictured below:
Thanks!
Re: SFA Powersteering Gearbox Oil
YOU wrote:Does the power steering A/T fluid run through the entire box and lubricate it by any chance?
Yep. :winkx:
Tim86
Real Name: Tim
Post by Tim86 »
:thumbup: :thumbup:
pampoen
Town: Gordons Bay
Vehicle: 2011 Hilux DC 3.0 D4D
Real Name: Luke
Post by pampoen »
Did you rebuild yours? If so where are the pics man! :clap: :clap: :clap:
Tim86
Real Name: Tim
Post by Tim86 »
Nah just slowly replacing all fluids etc. No leaks, if it aint broke, don't fix it haha.
Luke what is your carby setup now? I think I saw on Faceboet that you are running a Weber?
Why so if your Aisin was also getting 8km/l with the modification to it?
Tim86
Real Name: Tim
Post by Tim86 »
What would be the best ATF fluid to use? And approximately how much will it take?
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Post by The Legend »
Tim86 wrote: Wed Oct 10, 2018 7:06 am What would be the best ATF fluid to use? And approximately how much will it take?
0,85 liter
I've used Castrol for a long time without any issues. I also use it in my hydraulic jacks so buy 5lit at a time ... not too pricey either. :winkx:
Tim86
Real Name: Tim
Post by Tim86 »
Thanks guys, fortunately bought 1L of the Castrol ATF Dex II today, which apparently matches the Dexron specified in the manual. Not pricey at all.
pampoen
Town: Gordons Bay
Real Name: Luke
Post by pampoen »
Tim86 wrote: Tue Oct 09, 2018 8:49 am Nah just slowly replacing all fluids etc. No leaks, if it aint broke, don't fix it haha.
Currently I am running a weber 32/36. The Aisin I had on had the carburettor enhancer setup on it and it was ok on the open road but it was not idling well at all, I had it rebuilt by a reputable shop and even after they replace all jets and checked it out it still ran like crap. Realistically now I am getting 7.8km/l on the open road and about 6.5km/l in town if I don't drive like a taxi. Its my daily driver so I am sure about the mileage. And after the timing chain rebuild it runs soooo much better.
Tim86
Real Name: Tim
Post by Tim86 »
Do you think the carby enhancer caused it to idle poorly or was it merely the carb itself?
I haven't got to it yet but I plan on running the enhancer vacuum line into the cab with the needle valve on the dash so I can tune it, mark the setting and then easily flip it off for town/stop-start driving (smoother idling...?) and on for the lang pad. Have you considered implementing the enhancer on your new Weber?
Agree wholeheartedly - new chain is a win in all respects.
Do you also have the Brospeed cam and what is your timing set at?
pampoen
Town: Gordons Bay
Real Name: Luke
Post by pampoen »
Do you think the carby enhancer caused it to idle poorly or was it merely the carb itself? With the Carb enhancer connected and disconnected it still ran badly, I have a video actually where you can hear it coughing and spitting through the exhaust. I am not sure what it was to be honest, all I know is after we installed the Weber it was a whole different machine, smoother more power and muuuch more economical.
At worst the carb enhancer gave it a slight dead spot as you take off, but the manual does say it will do that.
I haven't got to it yet but I plan on running the enhancer vacuum line into the cab with the needle valve on the dash so I can tune it, mark the setting and then easily flip it off for town/stop-start driving (smoother idling...?) and on for the lang pad. Please let us know how it works out for you.
Most definitly, I wanted to get the bakkie back to normal runing condition and already with the new vacuum advance and weber i am getting the above mileage.
I actually shelved the cam for a standard cam like mud dog did with his Hilux. I am running standard timing specs at the moment.
