Transfer Box "Clank" on G52 5 Speed Gearbox
Posted: Wed Aug 15, 2018 2:14 pm
Hello All
Looking at the picture, holding both ends of the input and rear prop shaft side output shafts and turning them in opposite directions there is lots of play and what feels like jumping or skipping a spline. something is loose/worn out inside and its not good. I noticed this when the transfer box was still bolted to the gearbox and turning the flange in any direction
I thought it was the rear prop shaft output side flange splines that was worn out so I removed it. Using 2 vise grips I found the same play/ clank or skipping of splines so I can safely eliminate the flange as the problem. I am not a fundi on this type of stuff and was hoping one of you guys came across or know of something like this.
I am on a tight budged, if someone can help me to diagnose the problem it will be a huge help and I am sure I will be able to fix it myself....
