Prado Gearbox
Posted: Fri Jul 27, 2018 2:31 pm
by mcw
Hi Guys
my Prado auto box is making a whining noise and oil is not red any more, auto gearbox specialists ,says
the clutch material is coming loose and clogs filter then pump whines.
Any one know of a secondhand box lying around that i can buy,rebuilding mine to expensive
Martin
Re: Prado Gearbox
Posted: Fri Jul 27, 2018 5:26 pm
by Family_Dog
Geez, sorry to hear about this, Martin. Speak to JohanM, you might be able to salvage the gearbox from his old Prado from whoever has it now.
Re: Prado Gearbox
Posted: Fri Jul 27, 2018 6:06 pm
by mcw
tks Eric
i will contact him
Re: Prado Gearbox
Posted: Fri Jul 27, 2018 11:40 pm
by LouisZ
Ask he guys that import the V8 Lexus engines. Sometimes a guy takes the engine with out the autobox. These boxes are similar to the Prado 120. Ask if it will work with the 90.
Re: Prado Gearbox
Posted: Wed Aug 01, 2018 6:08 pm
by mcw
hi guys
So i followed the resident experts advice (Louis) and contacted Lextrene
according to them all that is needed is different bell housing and the 5 speed A650 box fits to my Prado
no problem with t/case bolts to box
At R4500.00 for both ,lot cheaper than 26000.00 quote from gearbox place
will visit them on Friday to confirm
Martin
Re: Prado Gearbox
Posted: Wed Aug 01, 2018 6:20 pm
Re: Prado Gearbox
Posted: Wed Aug 01, 2018 8:25 pm
by Family_Dog
Shot, Martin!
Re: Prado Gearbox
Posted: Wed Aug 01, 2018 8:32 pm
by JohanM
Martin
Just check your Vin plate on the firewall. The Prado 90 did not use the A650 box. It used the A343 Gearbox.
The A650 is a 5 speed gearbox and the ECU on your Prado is 4 speed so the ECU and gearbox is not going to like each other very much and also the gear ratio's do differ a lot. Rather just ask N14x4 for a price on the correct gearbox. I know they have 2/3 90 series Prado's there all automatic.
The A343 Gearbox ratio's are like follows:
1st 2nd 3rd O/D Reverse
2.804:1 1.530:1 1.000:1 0.753:1 2.393:1
The A650 Ratios:
1 2 3 4 5 Rev
3.357 2.180 1.424 1.000 0.753 3.431
Re: Prado Gearbox
Posted: Mon Aug 06, 2018 6:24 pm
by mcw
hi Guys
After having spoken on the phone to Lextreme and thinking they may have misunderstood what i was asking,i went there to talk to them(not far from my work)
I would need an adapter plate for both engine and t/case to fit Lexus box,tks Johan for info.
So back to square one looking for a gearbox
Martin
Re: Prado Gearbox
Posted: Mon Aug 06, 2018 8:40 pm
by RMD4x4
Hi Martin,
Did you give Toyota & Colt Spares a try? They mainly salvage parts from accident damage vehicles. Maybe, just maybe they can help you with a decent mileage box.
Johann
Re: Prado Gearbox
Posted: Tue Aug 07, 2018 5:46 pm
by mcw
hi Johann
i will contact them
Martin
Re: Prado Gearbox
Posted: Wed Aug 15, 2018 10:24 pm
by mcw
So i finally got in under the Prado today to look at the identification plate on gearbox
this is the gearbox fitted
A340E (30-40LE)
The detachable bell housing, which attaches the main transmission case to the engine, has an engine-specific bolt pattern, which appears on its upper surface as cast-in letters. "J" indicates the straight-6 1/2-JZ engine, "U" the V8 UZ engine.
Applications (calendar years):
1987-1992 Toyota Cressida (30-40LE)
1986-1993 Toyota Supra (MA70)
1986-1992 Toyota Supra (GA70)
1990-1993 Toyota Supra (JZA70)
1993-1996 Toyota Supra (2JZ-GTE) (JZA80)
1990-2000 Toyota Chaser/Mark II/Cresta 2.5 (1JZ-GE)
1995-2013 Toyota Tacoma 2.7L I4 (2WD), 3.0L V6, 3.4L V6
1993-1995 Toyota T100 3.0L V6
1993-1998 Toyota Previa 2.4L w/supercharger
1991-1997 Toyota Aristo (2JZ-GE)
1992-2000 Lexus SC 300/400
1990-1995 Toyota Crown Majesta 3.0L I6
1999-2003 Toyota Crown Athlete V (1JZ-GTE)
1991-2000 Toyota Soarer
1995-1997 Lexus LS 400
1989-2003 Toyota 4Runner (4x2) (30-40LE)
2001-2004 Toyota Sequoia (4x2)
2000-2004 Toyota Tundra (4x2)
2005-2007 Toyota Commuter 2.5L
1985-1995 Toyota Pick-Up 3.0L
1990-1994 Volvo 960 3.0L
2004-2009 Isuzu D-Max (4x2)3.5L V6
2004 Isuzu Axiom 3.5L V6
2004 Isuzu Rodeo 3.2L and 3.5L V6
2008 Isuzu d tec 3.0l 4x4
1 2 3 4 Rev
2.804 1.531 1 0.705 2.393
so now the search is on again
Martin
Re: Prado Gearbox
Posted: Thu Aug 16, 2018 6:44 am
by Mars
Good information. Thanks Martin and good luck with the search.
Re: Prado Gearbox
Posted: Thu Aug 16, 2018 12:31 pm
by JohanM
Martin,
What is the gearbox code listed on your VIN Plate in the engine bay located on the firewall? That is the gearbox you will have to source. The A340 and A343 boxes were much the same but the A340 were more known for overheating when towing. It seems like your Prado has had a gearbox problem before and then they replaced it with this one.
But I am speaking under correction here. Prado 3.4V6 5vz-fe engines all had the A343 boxes fitted.
Re: Prado Gearbox
Posted: Thu Aug 16, 2018 12:35 pm
by JohanM
Also take note that the OD ratio is different on the two boxes with yours being slightly longer geared which will lead to more frequent down shifts.
Standard tyre size 265-/70R16 you should be on 122 approx at 2500 RPM and 140 on 3000 rpm.
Re: Prado Gearbox
Posted: Thu Aug 16, 2018 6:18 pm
by mcw
Hi Johan
i just checked the VIN plate has a343f on it
i am still looking for a box
Martin
Re: Prado Gearbox
Posted: Fri Aug 17, 2018 1:49 pm
by JohanM
mcw wrote: ↑Thu Aug 16, 2018 6:18 pm
Hi Johan
Martin
Hi Martin
Your best option would be to speak to N1 4x4. The A343F gearbox was used in the 100 series VX cruiser as well as the VX TD 80 series and other models. The will have one there. I was at the yard about 3 weeks ago and there were 4 x Prado 90's stripped for spares and some had to be auto as I have seen one was petrol which by default was automatic.
Re: Prado Gearbox
Posted: Fri Aug 17, 2018 6:12 pm
by mcw
hi Johan
Dankie ek sal weer probeer
was al eenkeer daar en het drie keer gebel ,se atyd ons moet gaan kyk sal jou bel dan hoor jy niks njie
diens maar treurig .
Martin
