Hi all,
My retired dad drives a 2005 2.5 Diesel (2KD ) Hilux 4x4 , he has replaced the turbo twice with a reconditioned unit, the last one about 8000km ago.
The second replacement is now again starting to make screeching noises from hell.... (as soon as the warrantee expires)
Turbo Serial no. 17201-30120.
The Local turbo "specialist" in town's immediate response was that the turbo does not get enough oil but we did an oil pressure test and it shows above 3 bar at 2000 RPM at the turbo.
Is there any specifics one should look out for on these reconditioned turbo's or any specific turbo shop one can trust to fix it properly?
Any comments or advice will be welcome.
2.5 D 2KD Turbo Reconditioning
- Jaws
- Town: Sharonlea
- Vehicle: 2009 D4D 4x4
- Real Name: Herman
Re: 2.5 D 2KD Turbo Reconditioning
Did you also check the oil drain from the turbo ?
Gaan draai by Turboworks in Centurion
