Hi all.
Some help please. Does the 3L D4D in my Hilux have an EGR cooler/valve? My VW bus has it and I have been advised by an agent to have the cooler removed as they give trouble. I don't want the same problem on the Hilux. I think some-one said it does not have one. Is this true?
Many thanks
Docbos
EGR cooler/valve
- FIRSTGEER
- Town: King WilliamsTown
- Real Name: Tony Geer
- Club VHF Licence: HC 109
Re: EGR cooler/valve
Howzit and welcome Marcus.The d4d does have an egr valve and many owners have them blocked off.I in fact have a 2,5 d4d and had the valve blocked off as soon as I had purchased my 4x4 about 3 years and 100 k kms ago.
The norm is to make up a gasket on the flange without the centre flow hole opened.
Use the thin metal type of gasket material used on engine gaskets.
- Town: Amanzimtoti
- Vehicle: 3L D4D Hilux 4x4 DC
- Real Name: Marcus
So I just have the EGR blocked off. On the engine side or the exhaust side? if that makes sense.
Does it have a cooler that needs to be bypassed?
Thanks Tony
Thanks Tony
Ja, get rid of it asap!
I know of a bus tthat popped the EGR cooler - the bill is already past R50k and counting...
- Jaws
- Town: Sharonlea
- Vehicle: 2009 D4D 4x4
- Real Name: Herman
No Hilux only has an EGR valve just leave it.docbos wrote:Hi all.
Many thanks
Docbos
On the VW they ciculate engine coolant trough the EGR system to cool the gas. This is usually where water gets into the engine . I have a friend sitting with his Amaroks engine that got damaged due to the EGR cooler letting water in.
To be fair he made it 400k km
Sent from my SM-G900F using Tapatalk
