Airbag indicator light
Mikie
Town: Kyalami
Vehicle: Hilux 2006 3.0D4D 2x4 DC
Real Name: Mike
Post by Mikie »
My 2006 3.0 D4D yesterday decided that it should permanently inform me that I have Airbags, it warning light stays on permanently
Anyone know what could cause this?
Any ideas on how to rectify it?
Maybe disconnect the battery for a while to reset the error?
lukestoyzx
Town: Griffith
Vehicle: 07 Hilux SR5
Real Name: Luke
Re: Airbag indicator light
Post by lukestoyzx »
Very common problem mate. It'll be the airbag clock spring in the back of the steering wheel. As I said it's very common, toyota did a recall on them years ago.
Die$eL
Town: Midrand
Real Name: Nishan
Post by Die$eL »
You can still take it to Toyota for the recall. They will repair it free
Real drivers use three pedals
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
Thanks Gents, I will go past a dealer and see what they say about it
lukestoyzx
Town: Griffith
Real Name: Luke
They'll be able to look up you chassis number an see if it's done b4. If it hasn't they'll do it free otherwise get a clock spring on ebay and do it yourself.
Die$eL
Town: Midrand
Real Name: Nishan
Post by Die$eL »
even if it was done before they will probably do it again.
They did my Fortuner twice. Apparently the batch they used for the first recall was defective
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
Shot guys
pieta.swanepoel
Real Name: Pieta
Post by pieta.swanepoel »
I accidentally disturbed one of the wire plugs of the airbag sensor, that caused the light to come on when I was busy fixing one of the air vents. Maybe just check behind the glovebox if there is not a loose wire plug
lukestoyzx
Town: Griffith
Real Name: Luke
Make sure ya have the battery disconnected for a good ten minutes b4 ya fiddle with any airbag wires. Wouldn't want an airbag goin off in ya face!! It hurts!
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
So its now intermittent, off most of the time, bu every now and again it decides to stay on after starting
ERJ
Town: Stellenbosch
Vehicle: 3L Hilux 4x4 Xtra cab
Real Name: Ruben
Post by ERJ »
Hi all, I have a brand new Clock Spring or Spiral Cable for a 2013 Toyota Hilux for sale.
This tread was a real lifesaver when I needed it. My horn only worked intermediately, only when turning the steering wheel.
I was in Kenya at the time and had to buy a new one from Toyota in Stellenbosch because in Kenya, the Toyota recall was not valid.
And as you will agree, you can’t drive through Africa without a horn.
So once i got back in SA i send the bakkie in for the Clock Spring recall (free replacement), so now i still have a brand new Clock Spring (7000 km only).
I paid R 2700 for this piece of plastic!
Will sell for R 1500, and help you replace yours, even give you a cold beer while your wait. I’m in Stellenbosch.
Phone me at 082 seven 643 seven 32
Regards Ruben
Bostik
Town: Bellville
Vehicle: 2008 Hilux 3.0
Real Name: Hermann
Post by Bostik »
What are the chances they still honor the recall today?
Does anybody know?
Regards
pieta.swanepoel
Real Name: Pieta
Gaan vra. Ek dink hulle behoort nog as dit nie alreeds gedoen is op die voertuig nie.
Download toe MyToyota app op jou foon en jy kan sien watter recall is uitstaande. Gaan teen die VIN no
Of hulle vooraad het is 'n hele ander saak
dalkill
Town: Cape TOwn
Vehicle: 2.4 GD6 SR D/C 4x4
Real Name: Shaakir
Post by dalkill »
You can also check on their website.... that how i checked mine and booked it in...
https://www.toyota.co.za/owners/toyota-recall
TOYOTA IS MY LEWE
Bostik
Town: Bellville
Real Name: Hermann
Post by Bostik »
Dankie julle, ek gaan hulle kontak. Sal laat weet wat hulle se.
