Rear lights not working
Barista
Town: Alberton
Vehicle: Hilux 2.7
Post by Barista »
I replaced the factory fitted radio in my 2003 2.7 Hilux. I did not change any wiring. I only adapted the radio's wiring to suit the vehicle's wiring. Problem is that the instrument cluster's lights are now not working and also the rear lights are not working. I.E. The instrument panel light, both rear lights and the number plate light. The brake lights and the reverse lights are working fine.
What did I do wrong?
GRWLR ZN
Town: Richards Bay
Vehicle: Toyota Hilux - Lexus V8
Re: Rear lights not working
Post by GRWLR ZN »
Eesh boet,
Welcome to the forum ,firstly. :thumbup:
Did you use the standard plug wiring that was used for the factory radio? Did you add an amp or anything else?
Check all your fuses first, perhaps you touched a live wire on something during fitment.
:mrgreen:
Dadz Toy
Vehicle: 95 Series Prado - Diesel Dog
Real Name: Richard
Club VHF Licence: HC 286
Post by Dadz Toy »
Sounds like a fuse!
Rich :cooldude:
Rich :cooldude:
Borntofish
Vehicle: Hilux 86
Real Name: Werner
Post by Borntofish »
Open the stalk switch an clean the contact points.
Post by CasKru »
Did you disconnect the battery before you started with the installation? If not, you've probably popped a few fuses
Barista
Town: Alberton
Vehicle: Hilux 2.7
Post by Barista »
Thanks for the replies gentlemen.
Took the Hilux to an auto electrician yesterday. This problem was not related to the radio. For some obscure reason there was a short in the wiring at the rear lights. The connection going to the towbar. Anyway the problem was sorted.
