2700 i Vibration on Pullaway - What is it??
- Town: bethlehem
- Vehicle: 98 Nissan Patrol GRX, 1996 Hilux 2,4 D S/Cab SFA, 2007 Merc CL 500
- Real Name: petri
I bought a 2700 a while back.
The vehicle has a slight vibration on pullaway. It's not clutch, and not propshaft (I had those checked).
What else can this be?? Mounting?? It's just at pullaway, no other issues then, the car runs perfectly.
" Fear?? Looking over at Joe Louis' Corner, and knowing Joe wants to go home early tonight"...….Max Baer
Re: 2700 i Vibration on Pullaway - What is it??
Sounds like a clutch shudder. I know you say you had it checked but even a brand new clutch can shudder,specially if it has not been properly aligned with an alignment dowel when fitting the pressure plate. Shudders can also be caused by a burnt clutch plate or pressure plate.
Check al the mountings first to eliminate that as a possibility, if it's not that, then replace the clutch plate, pressure plate and have the flywheel surface skimmed lightly. Replace the release bearing & spigot shaft pilot bearing at the same time.
- Town: bethlehem
- Real Name: petri
Thanks Mud
I've been thinking about tyres today - it literally feels like a tyre with a knob in it (but just slightly so). It's not a shudder - feels like you're pulling away over some small klippies.
Maybe I'm full of crap, and no-one else feels it. But I do.
- Froll
- Town: Vioolsdrift
- Real Name: Roger
- Club VHF Licence: N/A
I dont want to make you worry, but when I stripped my truck to do the overhaul now, I had a slight shudder on the clutch. When I removed the motor I found that the pilot bearing was not in place, it was wedged in the clutch plate so it could not have fallen out when I removed the motor.
- Town: bethlehem
- Real Name: petri
Forgot to mention - it also had a noise at around 100, I delivered an Echo 3 in Pretoria last week and sommer took the Lux. I then sent it to Propshaft place, they fitted a "sleeve and ??", and balanced the whole lot.
That shudder on pullaway was a bit better since then - but still there.
It's not a clutch I think. If you pull away at idle, it's 100%. Or if you pull away briskly, it's also 100%.
Again, this is VERY feint guys. I've felt it on previous Luxes before, but on others not.
Mileage is on 263 000, if that helps.......??
- ismail
- Vehicle: Hilux '03 2700i SC 4x4
- Real Name: Ismail
How old is the new clutch. Had similar issue after 1000km it went away but I also found a cracked mounting on the bellhousing which I replaced.problem went away. So my problem was really 2 fold but an easy fix
I surf more than I work
- LouisZ
Flywheel skimmed?
If not its a guaranteed shudder.
- Town: bethlehem
- Real Name: petri
Guys - no, this is not a clutch shudder. The (really slight, but there) vibration is when you "already pulled away"..........meaining, if you let it coast in first at idle and floor it, the vibration is there.
I thought propshaft, had the thing balanced and new whatchamakolits fitted - it's slightly better, but still there.
Not a trainsmash - some may not even notice it. Bit is IS there. I'm finnicky with cars.
I've once before experienced something similar and not sure if yours might be the same problem. It was indeed the clutch plate .... the small radial coil springs in the plate that help to cushion any jerk, sudden acceleration etc were a bit weak and resulted in a sort of jerky "shudder" at times (not necessarily under pull-off - would even do it up to 3rd gear, especially under load).
If it's bothersome enough, I would do the clutch and be done with it.
- Town: Centurion Gauteng
- Vehicle: Mazda Rustler 16v
- Real Name: Jan
If the Hilux has a raised suspension setup it could the propshaft angles thats causing the vibration only on pull away
- Town: bethlehem
- Real Name: petri
Mud - thanx
MC - You're right, I actually forgot about this. It has OME suspension.
Not a deal breaker, but will be nice if it's sorted. Thanks again, will look into all possible causes.
- Knuppel
- Town: Somewhere in Africa
- Real Name: Marius
I do not agree.LouisZ wrote:Flywheel skimmed?
- Knuppel
- Real Name: Marius
MCHILUX wrote:If the Hilux has a raised suspension setup it could the propshaft angles thats causing the vibration only on pull away
Very likely.
- LouisZ
Every time I left a flywheel not schemed with a new clutch replacement it shuddered. Do not matter if its a Hilux, Corolla, golf, Jetta. These was my own vehicles. Not fun to take everything apart to get the flywheel out to get the work done properly. After no shudder.
So its my norm now to insist on the flywheel to schemed with a new clutch replacement.
- Knuppel
- Real Name: Marius
If there are no high spots or grooves from the rivets on the flywheel it is best left alone. Everytime you skim the flywheel you bugger up the balance. May lead to vibrations and bearing damage.
- Town: bethlehem
- Real Name: petri
maak mens SUPER gatvol, Louis - halwe werk. Gaan HELSE job wees om dit uit te sort, as dit die flyweheel is. Klomp ure se arbeid.LouisZ wrote:Every time I left a flywheel not schemed with a new clutch replacement it shuddered. Do not matter if its a Hilux, Corolla, golf, Jetta. These was my own vehicles. Not fun to take everything apart to get the flywheel out to get the work done properly. After no shudder.
- Knuppel
- Real Name: Marius
Petri, met al jou jare onderving weet jy mos teen die tyd of dit n clutch shudder is of nie.
- Town: bethlehem
- Real Name: petri
Beslis nie clutch shudder nie, Marius. Ek en die laaities het die naweek bass gevang, en die Hilux trek die bootjie uit teen 'n steil helling - GEEN shudder nie.
Ons het een aand gaan jakkalse soek, in 4x4 deur los sand (ou lande) voel dit vir my of die vibrasie weg is - maar kan my verbeelding wees. Sal later vandag weer kyk.
Voel soos 'n ge "wopte" propshaft teen lae spoed - asof iets nie lekker in lyn is nie. Maar het klaar daarna laat kyk. Bietjie beter, Klannie het nuwe goete ingesit en propshaft gebalanseer, ens ens (hy het getril op so 100km/h). Nou doodstil - dis net daai good vibrations.
Kan oon nie 'n mag wees nie, hy maak so op die los grond ook.
BAIE min, maar hys daar. Hy word amper "beter:, maar dis dalk omdat ek hom gewoond raak.
- Mornes
- Town: Roodepoort
- Vehicle: Hilux 4.0 DC 4x4 AT
- Real Name: Morne
Petri, het jy toe jou pul away vibration probleem kon oplos?
Sent from my SM-G950F using Tapatalk
Morne' Smuts
Toyota Hilux 2007 - 4.0 DC 4x4 A/T: TRD Supercharger, OME Suspension, Outback Canopy, 29Mhz Radio, 32 BFGR Tyres, Unichip, Echo 4 Trailer, Duel Battery System, Snorkel, ARB Bumper
Hy het daai bakkie laaaaaaaaannnnnkal weer verkoop - hy is 'n kar smous van beroep.
'n Moontlikheid wat nie genoem word nie is die centre bearing. Ek het my Kz lank genoeg gery om deur elke moontlike vibrasie te werk.
Een keer was die centre bearing self onderstebo ingesit....deur die uwe!
Ha Ha, ek het gistrer dieselle met my trokkie gedoen. Gelukkig was Hoppy daar om my reg te help en te verduidelik dat die een gaatjie altyd moet ondertoe wys en die twee gaatjies boontoe.Een keer was die centre bearing self onderstebo ingesit....deur die uwe!
- GTO
- Town: Fish Hoek
- Real Name: Stephen
My 2700i also has developed a shudder clutch has 140000km on it(330000km on vehicle), clutch was changed when Input shaft bearing packed up at 190000km.
Mine shudders on pull away and also in reverse but if I increase the revs to a bit higher than I would normally pull away at its much better.
Also noticed it even changing to 2nd but its not as pronounced.
I am pretty sure its the clutch.
Its been like this for a few months now, just reluctant to spend money on clutch that probably has a lot of life left on it, on my 2.4 SRX I got 290000km out of the original clutch.
1985 Suzuki DR600S
1984 Honda ATC200ES BIG RED
1985 Suzuki DR600S
It does sound like a clutch shudder. Unfortunately it doesn't go away.
- Vehicle: Toyota Hilux 4x4
- Real Name: JAMES
If you're satisfied that's it's not the clutch, I would suggest that you carefully recheck the u-joints. My truck had a vibration at startup and at around 86 kph. Turned out there was a single needle bearing missing from one of the rear u-joint caps. Replaced the joint and now 100%.
- JAMES
- JAMES
