The power steering pump on Ryperd suddenly started leaking badly, and then seems to have failed completely (it's no longer leaking, but there's also no more power steering). I can get a replacement from Gemini (which they assure me comes from Japan, not China) or I can get it overhauled at CV Master in Pretoria West. CV Master was recommended by the Toyota dealers. Apparently the power steering pump has been discontinued through Toyota, so can't get it OEM anymore.
Any recommendations on new vs overhaul for the PS pump?
SFA power steering pump - replace or overhaul?
- Ryperd
- Vehicle: 1994 Hilux D/C 2.2 Petrol (4Y SFA)
- Real Name: Rudi
- Club VHF Licence: X93-
Re: SFA power steering pump - replace or overhaul?
Ek sal se laat hom oordoen as jy n waarborg kry vir die werk gedoen. Ek het Gemini parts vir baie jare ondersteun,maar begin nou vertroue in hulle parte verloor.
- Bliksempie
- Town: Pretoria Montana
- Vehicle: 2.4 SFA
- Real Name: Robbie
- Club VHF Licence: HC115
Rudi,
Ek het met dieselfde problem gesit. Kyk gerus na hierdie link wat ek toe gedoen het:
viewtopic.php?f=3&t=39431&p=466877#p466798" onclick="window.open(this.href);return false;
- Borntofish
- Vehicle: Hilux 86
- Real Name: Werner
Moenie dit se nie, het net laasweek n nuwe slave en master clutch by hulle gaan koop!Ek sal se laat hom oordoen as jy n waarborg kry vir die werk gedoen. Ek het Gemini parts vir baie jare ondersteun,maar begin nou vertroue in hulle parte verloor.
Bliksempie wrote:Rudi,
Robbie
Jy en Rudi het nie dieselfde probleem nie. Jy het n power steering box probleem gehad. Rudi het n power steering pump probleem.
- Bliksempie
- Vehicle: 2.4 SFA
- Real Name: Robbie
Askuus my fout. Te vining op die band wagon gespring daar.
- Ryperd
- Real Name: Rudi
Dankie almal, ek dink ek sal dit recondition. Goed om te weet van West Power Steering. Miskien sal ek dit daarnatoe vat en nie CV Master wat Toyota aanbeveel het.
- louis fourie
- Club VHF Licence: X101
Re: RE: Re: SFA power steering pump - replace or overhaul?
+1 het my fingers...en beursie al lelik gebrandThe Legend wrote:Ek sal se laat hom oordoen as jy n waarborg kry vir die werk gedoen. Ek het Gemini parts vir baie jare ondersteun,maar begin nou vertroue in hulle parte verloor.
- Vehicle: Hilux SFA
- Real Name: Rodney
Don't have that problem.But can be a pain without power assisted steering.
