Hello Folks,
Please dont string me up here but I cannot locate the lever to lower the rear seats in my DC
2007 DC/RB 3.0 d4d
Any pics/help/videos (LOL) please
Very Simple.....To you maybe
- Town: Potchefstroom
- Vehicle: SRX 2.5 4x4 D/C
- Real Name: James
Re: Very Simple.....To you maybe
It is in the middle of the bench seat. So follow the center console, to the rear, and you will see a little loop (should have a longer loop with a hook attached to it. You pull this and the bottom bench will come loose and can fold back 90 degrees. You can then hook the longer loop to the back to keep it in that position.
James Cameron
0834431879
0834431879
- Town: Table View
- Vehicle: Hilux D4D 4x2
- Real Name: Jody
Yea that i have done but im sure the back seat goes forward? I cant seem to locate the wheel spanner and lowering rod etc
Not sure if it's any different on your later model, but on the old models the lower rear seat is secured rigidly and does not move forward. Wheel spanner, jack and jack handle are normally secured against the rear firewall - some jack handles were incorporated into a tool-roll and the crank rod to lower the spare is usually clipped against the rear firewall.
- Real Name: James
Once you have lifted the bench seat, there are two flaps, wheel spanners and jack inside these boxes under the bench and not at the back behind the upright seat...
James Cameron
0834431879
0834431879
- Real Name: James
And if those two boxes are empty you have no jack and wheel spanner...
James Cameron
0834431879
0834431879
- Jaans
- Vehicle: 2005 4L V6 DC Hilux; Pajero Sport 2.5 4x4 M/T
- Real Name: Johannes
That is correct your jack and tools should be in the one box under the seat.JamesC wrote:And if those two boxes are empty you have no jack and wheel spanner...
The seat cannot fold forward like the older models. It is possible with a modification, you can search on the this forum for detail.
1 Kor 1:18 " Die boodskap van die kruis van Christus is wel onsin vir die wat verlore gaan, maar vir ons wat gered word, is dit die krag van God."
jip, exactly like that in the Legend35 - 2005 model as well.JamesC wrote:Once you have lifted the bench seat, there are two flaps, wheel spanners and jack inside these boxes under the bench and not at the back behind the upright seat...
- Real Name: Marnus
You pull that release lever - there should be a strap attached to it that you pull and then you lift up the seat. It hinges up from the front. The tools and jack are located in two bins underneath the passenger seat. They are covered with carpeted covers and clearly visible. The rear backrest does not unhook and hinge forward unless you modify it somewhat. There is a thread on that in this forum. Just do a search.
