4Y wil nie vol oopmaak nie.
- Umvubu
- Town: Lydenburg
- Vehicle: Hilux D/C 4Y & Hilux S/C 2.4D & Musso 602EL
- Real Name: Ezere Du Plessis
My 4Y het nog die oorspronklike Nikki carb in. Dis 3 weke terug deur die Toyota agente gediens. Ek het gevra dat hulle die carb ook diens, want dit voel die Lux wil nie vol oopmaak nie. Daar is toe skoon gemaak en parte vervang in die carb, die resultate is nie 100% nie. Ek sukkel om 100km te haal op gelyke pad. Ek weet groter bande het 'n uitwerking op performance maar nie so kwaai nie, dit voel asof sy "ppol"(daar is nie 'n beter woord nie) verstop is. Raad.....
1993 Hilux 2.4D S/C - 31" Khumo Muds , Lockers F/R , OME Suspension , Snorkel , Extended Shackles etc
1996 Ssanyong Musso 602EL - OME Suspension
Re: 4Y wil nie vol oopmaak nie.
Hi there,
I would start by checking the timing. The young mech's of today are not that clued up on the 4Y, so they check the manual that states ign. timing @ 4deg. If they set it to 4deg, you will have that 'lazy, can't get going feeling'. Of course that depending on whether you live at low or high altitude. I would check that it is set at about 8deg. If the problem remains then it may be that the second stage of the carb is not opening.
B
B
Best solution:
Book Bennie the Wizard
Be quick though;
His EFi Services are in Big Demand lately
Rich
Be quick though;
Rich
