Hi Guys
I my KZTe has started using a lot more diesel recently and is a bit down on power. the injectors have never been redone (244KKm on the clock),
however I got a quote from northern diesel and they want to recon the pump as well.
I want to get a second opinion, are there any good diesel repair shops either in Pretoria or Bedfordview/kempton area
Diesel injectors and pump repair shop
- Town: Table View - CT
- Vehicle: 4x4 3.0KZ-TE 2002
- Real Name: Lourens
Re: Diesel injectors and pump repair shop
Robert, my KZ was ook bietjie min in krag in 2012.
Na baie toets (en geld) was die "spill valve" vervang en diesel pomp oorgedoen.
Terselfde tyd die turbo "recon".
NOU TREK KZ SOOS TREIN...
Miskien help hierdie info bietjie waarna om te kyk.
- Real Name: Rian
Robert, sien jy is in Pretoria. Northern Diesel (Bosch) is in Schubart str, Toyota koop hul injectors deur hulle. Probleem is net hulle is helse besig. Hulle het die beste toerusting beskikbaar.
- Real Name: Rian
Sorry Robert, sien jy het klaar Northern diesel gekontak. Jammer, Wat van Dastek?
- Vehicle: 2002 D/C KZTE 4x4
- Real Name: Robert
Dankie Rian
ek gaan volgende week die injectors laat doen en dan die kar dastek toe vat laat hulle die chip remap en op die dyno sit en diagnostics doen. dan sal ek dit verder vat as nodig
- louis fourie
- Club VHF Licence: X101
Northern Diesel het my dieselpomp in 2008 oorgedoen en verlede jaar die injectors. Hulle diens en kwaliteit is goed.
Sent from my IdeaTab S6000-H using Tapatalk
