D4D T-Belt light reset, the correct way;
Hoppy
Vehicle: Hilux SFA & IFS
Real Name: Allan 0721291160
Post by Hoppy »
The way on this topic; viewtopic.php?f=3&t=16006" onclick="window.open(this.href);return false; ; doesn't work.
You've replaced the belt with the corect long life belt, but the T-Belt light stays on :(
The T-Belt light will come on just past 150 000 km, whether you replaced the belt or not :problem:
There is no sensor, the light is activated by a timer in the cluster :o
This is the correct way :think:
1. Switch ignition on and select "odo"
2. Switch ign. off
3. Press selector and hold for 5 seconds, don't let go
4. Switch ign. on and hold for another 10 seconds
5. Release selector and press once, number 15 will apear
6. Press selector 15 times up to number 15
7. Press and hold selector untill odo re-apears, let go
8. Start vehicle, T-belt light is off :)
Re: D4D T-Belt light reset, the correct way;
Post by CasKru »
Nou wens ek ek het nog 'n D4D gehad dat ek dit kon toets... hehe
Post by Mars »
Dankie Hoppy.
Pote
Town: Hartbeespoort
Vehicle: Fortuner D4d 4x4 & VW Passat
Club VHF Licence: X228
Post by Pote »
My Fortuner se t-belt liggie het oor die naweek aan gekom.
Ek het nounet die probeer en dit werk. Die liggie is dood.
Baie dankie Hoppy :clap: :clap:
ThysdJ
Club VHF Licence: HC102
Post by ThysdJ »
CasKru wrote:Nou wens ek ek het nog 'n D4D gehad dat ek dit kon toets... hehe
Ek kannie wag tot my D4D 150 000 kms op die klok het nie sodat ek dit ook kan toets... Nog net 60000kms om te gaan... :twisted: :twisted: :twisted:
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
nog net 103 000 km dan kan ek dit toets .... :)
Dankie Hoppy !
Mikie
Town: Kyalami
Vehicle: Hilux 2006 3.0D4D 2x4 DC
Real Name: Mike
Post by Mikie »
Thanks Hoppy, my method on that thread did work though, I didnt press 15 times though, just 2, whats the difference there??
Mikie wrote:I GOT IT!!!!
Tried again this morning and by luck I cracked it
Dylan, your procedure isnt entirely right
Make sure your ODO is displaying and not trip meter A or B
Press reset button with Ignition off and hold it
Turn on ignition and start the engine while still holding button in, hold for at least 5 seconds and release,
DO NOT TURN IGNITION OFF
Press reset button again and a "1" should appear on the screen
If you press again a 2 will appear
I left mine on 2 as I assume this is for the second timing belt
Then press and hold the button in until the light goes off
VOILA!!!
Nobit
Vehicle: Hilux Legend 40, 3.0D4D 4x4 Auto
Real Name: Robert
Post by Nobit »
Ive got 3000km to go.....Yipeeee.
Will definitely try it out.
Thanks for the info Guys!
Riaan99
Town: Vredendal
Vehicle: Hilux 3l 4x4 dc
Real Name: Riaan
Post by Riaan99 »
1356km oor dan mag ek dit ook doen, jippy! Dankie vir daai 1!!
..die kalmste is om belangrik te bly...
vanthev8man
Town: wellington
Vehicle: 81 hilux 350,80 vx landcruiser,650 bombardier.
Real Name: martin
Post by vanthev8man »
nou julle manne moet nie net die knoppie druk nie.....
dis meer belangrik om die belt te vervang! :tease: :lmao:
hilux sfa -the only real 4x4!
subok
Town: Jhb - Somerset West
Vehicle: Hilux 3.0 D4D 4x4 D/C - Kitted for overlanding
Real Name: Kobus
Club VHF Licence: HC152
Post by subok »
Ek gaan myne more toets. Goldilocks was verlede Woensdag in vir haar 150K diens. Timing belt is geruil op 149600. Hierdie naweek op pad terug van Volksrust af, het die liggie aangekom op presies 150000km lesing. Sal more aand probeer. Dankie vir did raad. Is dit die manier waarop die dealers dit doen?
Hilux D4D
ORRA X130
4x4AG GP0228
subok
Real Name: Kobus
Post by subok »
Dankie! Dit het gewerk!
Hilux D4D
ORRA X130
4x4AG GP0228
Hoppy
Post by Hoppy »
One small edit, it now works for the old and new d4d
Torjak
Town: Vanderbijlpark
Vehicle: Toyota Fortuner
Real Name: Deon
Post by Torjak »
Mikie wrote: Tue Jun 04, 2013 7:29 am Thanks Hoppy, my method on that thread did work though, I didnt press 15 times though, just 2, whats the difference there??
VOILA!!!
Torjak
Real Name: Deon
Post by Torjak »
Mikie your desription work 100%. I've the cambelt at 150911km and now 60000km later the light came on again at 210911km can there be something wrong on the cambelt or do you think I didnot reset the light correctly the last time?
I will appreciate your opinion, thanks
Mikie
Town: Kyalami
Real Name: Mike
Post by Mikie »
How I think this works is as follows, foe every push the rest button you get a corresponding number on the display, but it seems for every 1 its 10000km
I suspect when you reset yours you left it at 6
If I were you I would try the procedure again and leave it at 9 this time, but just remember that at 300 000km you need to replace your belt, in case you dont get the reminder
