Glow Plugs Timer ? (KZ)
JJBotes
Town: Witbank
Vehicle: KZ-TE
Real Name: JJ
Post by JJBotes »
Kan iemand my dalk sê of daar iewers op `n KZ `n sensor is wat die temparatuur van die engin meet en sodoende die tyd wat die Glow Plugs aan bly beheer ?
My glow plugs kry net krag vir so 2 sekondes, maak nie saak hoe koud dit is nie. Die bakkie begin sukkel om te start as dit koud is.
Ek het die battery getoets by battrie center, hy is 100%.
:thumbup:
4x4Maniac
Real Name: Werner
Club VHF Licence: X120
Re: Glow Plugs Timer ? (KZ)
Post by 4x4Maniac »
Sover ek verstaan werk die Gloplugs met n relay en meet nie die temp nie. Kan verkeerd wees...
ORRA CALLSIGN X120
AKA Epsilon on 4x4Community
(2011 JKUR)
Rugged Ridge Light Guards
KC Spotlights
Previous:
Donkey
Town: Johannesburg
Club VHF Licence: X122
Post by Donkey »
The actual "pigtail" light on the dash stays on only for a few seconds, 2 or so, but if you listen nicely you'll hear the relay click a few more secs after the light has gone off on the dash. On colder days it stays on longer and hear hear it click. But if it's battling to start on cold mornings, maybe you should replace the glowplugs - easy job, hope you come right, :thumbup:
Tumelo Maketekete
3RZ
Real Name: Willem Grimsell
Post by 3RZ »
On my previous diesel I wired an LED with the appropriate resistor straight from the glow plug power bar to see how long the glow plugs stay on. On the Mazda the two also worked independantly, why I don't know.
JJBotes
Town: Witbank
Vehicle: KZ-TE
Real Name: JJ
Post by JJBotes »
Dankie manne. Ek het gister getoets en die Glow Plugs bly baie langer aan as die liggie. :thumbup:
Ek sal vandag die Glow Plugs vervang.
:thumbup:
JJBotes
Town: Witbank
Vehicle: KZ-TE
Real Name: JJ
Post by JJBotes »
3RZ wrote:On my previous diesel I wired an LED with the appropriate resistor straight from the glow plug power bar to see how long the glow plugs stay on. On the Mazda the two also worked independantly, why I don't know.
That sounds like a great idea, but how . . . . . ? Please give more detail.
:thumbup:
Tarquin
Town: Plettenberg Bay
Vehicle: Toyota 2.8D D/C 4x4 & Toyota 2.4D single 4x2
Real Name: Tarquin
Post by Tarquin »
did it start nicely after you waited for the relay to click? if it does then there is no need to replace glow plugs just be patient and wait for the click :thumbup:
JJBotes
Town: Witbank
Vehicle: KZ-TE
Real Name: JJ
Post by JJBotes »
Nope, still the same.
Didn't get time to to get the Glow Plugs yesterday. Will make a plan today.
:thumbup:
Donkey
Town: Johannesburg
Post by Donkey »
I'd leave it as is, just listen for the click, it's so audible anyway, also you'll see the dash lights go slightly brighter after the click, then you know she's ready to be fired up, easy as pie.
Tumelo Maketekete
Wildside.tt
Town: Hoedspruit
Vehicle: Raider kzte
Real Name: Mark
Post by Wildside.tt »
Hi Guys.
80amp fuse is blown.
How do u get that fuse out, has 2 screws on either side of fuse but fuse leg on right is covered by the housing.
How does the housing clip out to get to that screw?
