Single Helix S-Beam Coupling
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
Where can I find a Single Helix S-Beam Coupling in jhb? Most people in Klerksdorp don`t even know what I`m talking about!!!!!!!!!
Gertc
Gertc
Re: Single Helix S-Beam Coupling
Wot'cha talkin' about, Gert?
- Stef
- Vehicle: '98 LTD
- Club VHF Licence: X107
Probeer Fenner, weet nie of hulle nog in K'dorp is nie.
Anders kan jy Bircraft probeer in Jhb, die BMI group (Bearing Man) of SKF.
Sien RS components het ook http://za.rs-online.com/web/search/sear ... ss%20Steel
PS: Jy lyk vir my bekend (familie voorstel thread), was jy nie by die tegniese kollege K'dorp so '94/'95 se koers nie? Dink jy en Johan Meyer was saam in dieselfde groep saam met 'n paar vd Vall Reefs 'appies' ...
http://www.huco.com/products.asp?p=true&cat=508" onclick="window.open(this.href);return false;
Distributors: South Africa
ATI Systems CC
PO Box 1299
Vanderbijlpark
1900
Phone: 00 27 169 862 267
Fax: 00 27 169 862 278
Email: atisa@mweb.co.za
RS Components (SA)
1 & 2 Indianapolis Street
Kyalami Business Park
Kyalami
Midrand
Phone: 00 27 11 466 1565
Fax: 00 27 11 466 1577
Website: http://www.rssouthafrica.com" onclick="window.open(this.href);return false;
Micropower Instrumentation (Pty) Ltd
PO Box 4430
Randburg
2125
Phone: 00 27 11 462 1106
Fax: 00 27 11 462 1943
Website: http://www.micropower.co.za" onclick="window.open(this.href);return false;
Stafford Engineering (Pty) Ltd
PO Box 6363
Johannesburg
2000
Phone: 00 27 114 935 400
Fax: 00 27 114 937 008
Email: info@strateng.co.za
ATI Systems CC
PO Box 1299
Vanderbijlpark
1900
RS Components (SA)
Kyalami
Midrand
PO Box 4430
Randburg
2125
PO Box 6363
Johannesburg
2000
Toemaar, baie min in Pretoria verstaan ook!Gertc wrote: Most people in Klerksdorp don`t even know what I`m talking about!!!!!!!!!
Gertc
Vertel tog waar dit werk?
They're used to couple two rotating shafts that are mis-aligned and come in a wide range of sizes. The one in Gert's pic is a single helix ..... the helix spiral is machined from a solid blank (beam coupling) which then allows flexibility in the coupling without the backlash that is sometimes found in some other types. It would typically be used where the two shafts to be coupled meet at an angle. A double helix would typically be used where to shafts meet at a slight offset.
Don't know what Gert's intended use is, but there is a very wide range of applications.
They can also assist in reducing the transfer of vibration from one shaft to the other .... can be designed to fail at a predetermined torque so as to protect more expensive components ..... can be manufactured from a variety of metals depending on the application, but I think most commonly used is SS.Don't know what Gert's intended use is, but there is a very wide range of applications.
You're very warm, Andy! But I'll let Gert do the explanation when he's ready! ;)
Now I'm intrigued!Family_Dog wrote:You're very warm, Andy! But I'll let Gert do the explanation when he's ready! ;)
- Gertc
Thanks for all the info. I am busy with a home build cnc router to make sure the New and improved dual battery systems is something you guy wouldn't mind mounting in a lux.
Post pics of your set up when you're done!
- Stef
- Vehicle: '98 LTD
Also used in automated roulette wheels, more of a torque application in this case :wink2:Mud Dog wrote:They're used to couple two rotating shafts that are mis-aligned and come in a wide range of sizes. The one in Gert's pic is a single helix ..... the helix spiral is machined from a solid blank (beam coupling) which then allows flexibility in the coupling without the backlash that is sometimes found in some other types. It would typically be used where the two shafts to be coupled meet at an angle. A double helix would typically be used where to shafts meet at a slight offset.
Gert, why not use an old plotter with a Dremel mounted to it?
- Gertc
Stefan do you have a old plotter?
- Stef
- Vehicle: '98 LTD
I wish! Wanted to pull that stunt ages ago to cut out the balsa sections for my model planes straight from CADGertc wrote:Stefan do you have a old plotter?
We only have Design Jets at work (been asking around); seems old plotters are scarce.
Maybe a CNC engraver could do the trick?
There is another thing on the market more for scrapbooking type people that uses a blade with configurable cutting pressure, but at R20k I wouldn't butcher it to fit a dremel
