Hi everyone! I bought this bakkie a couple of weeks ago and tried to test the difflock today via the owners manual operating instructions. The manual says that when the difflock is switched on, a red light will go on and when moving slowly forward it will change to green to confirm that the two shafts has been locked. I tried it this morning, stopped on a flat straight tar road, engaged clutch, selected 1st, switched difflock on and pulled away slowly and drove a couple of meters very slowly in a straight line in 1st gear but the red light didnt change to green..
So it tells me that the lock isnt engaging? Surely the ''gaps'' in the diff shouldve alligned a couple of times because I drove about 50meters. Im planning a trip into the mountains soon and want to make sure that its working properly. Any advice or info will be much appreciated. Thanks.
2004 2.7i 4x2 difflock not working
- Town: George
- Vehicle: 2004 Hilux 2700i R/B
- Real Name: Werner
- Town: George
- Real Name: Werner
Re: 2004 2.7i 4x2 difflock not working
I forgot to mention that the red light is not flashing, it just stays on the whole time...?
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Hi Werner.Did you put it in 4L(Low range)it only engage in Low Range
- Royco
- Town: Stellenbosch
- Real Name: Roy
- Club VHF Licence: X88
Werner, I can't comment on your exact model, but my 98 model, and my current 07 both didn't change colour. They were both 4x4 - not sure if that makes a difference.
There are two separate indicator lights.
The green light is to show that 4x4 has been selected, and a flashing red means that the diff lock has been switched on, but not engaged. Once engaged it stays on solid red.
But, as I say, this is what I've experienced.
Werner... you have to be in low range and the diff will not engage if you drive in a straight line. After switching it on and preferably not on a sealed surface, drive in a circle so that the two side shafts turn at different speeds. This will then cause it to engage.
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
Werner's Hilux is a 4x2 Raised Body S/C Hilux. So no Lowrange here to engage. Vehicles came fitted with a vacuum operated diff lock IE Gearmax.
When the red light stays on it hasn't engaged. I would rather recommend you take the vehicle on a dirt road, switch the locker on and drive slowly off and simulate a lane change to see if it actually enagages.
Also If it does not engage it can be due to the fact that the vacuum pipe has either come loose at the diff or at the solenoid it self.
If not it might be that the unit itself is jammed from not being used or there might be a leak in the system somewhere else as it doesn't get enough vacuum then to actually engage the locker at the back.
Either way, it should be fairly simple and straight forward to fix.
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
4x2 like to get the solenoid stuck just for a test bypass the soleniod and see if it engage. My money is on the soleniod. Hear it is expensive to replace.
- Town: George
- Real Name: Werner
Thanks Johan, I took your advice this weekend and it seems that my difflock is working just fine. Thanks a lot for everyones advice!
