Hi Guy's need some help.
On my KZ-TE the dome light and the back lights on the vents and fan does not switch on. My first thought was that the fuse, but I checked it, no problem and the globes are all fine, any ideas?
KZ-TE Electrical Problem
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
- Club VHF Licence: X117
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
Re: KZ-TE Electrical Problem
Wayne
This is the electrical diagram for the dome light. Hope it helps. P.S. Is there power across the fuse?
Shout it we can help some more!
- Attachments
- 023il.pdf
- (40.09 KiB) Downloaded 98 times
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- Town: Randburg
- Vehicle: KZTE
- Real Name: Donovan
Hi Wayne
I had a similar issue, I lost dashboard and headlights as well though. Turns out it was the relay feeding power to circuits. Check if that kicks in when you swithc the ignition on.
Don
Don
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
Problem solved. Looks like a fuse did not make good contact, It started working after I pulled the fuses to check them.
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
My KZTE also had a small electrical problem. Turns out the conrod shorted the altenator out.
