Howdy Chaps
So here's a question that I'll need help on: Every now and then the car pops out of 1st gear when pulling away from a standing start. But strangely enough, not whilst under load or incline etc, only on a flat surface (2 wheel high range only)
There is no whine or noises coming from the gearboxs, no clutch slipping, no leaks. Any idea's as to why it might "pop" out? I conciously make sure it is fully engaged in gear before I release the clutch, and it still happens every-now-and-then.
My local toyota service dealer cannot find the problem either.
I have a 3lt KZ-TE 2004 4x4 d/c
Regards
T
Jumping out of 1st Gear (Hilux IFS 2004)
- Town: Blouberg-Cape Town
- Vehicle: Toyota 3lt Kzte
- Real Name: Martin
Safety 8th
Re: Jumping out of 1st Gear (Hilux IFS 2004)
Hallo Martin,
Dit kan wees dat jy hom net nie mooi in rat gesit het nie?
- witmamba
- Town: Sasolburg
- Vehicle: D4D 4x4 Lux + D4D 4x4 Tuna
- Real Name: Hans
Mine does the same, I was told that it is a 'link' in the gearbox. Can anyone else confirm this???
Life only starts . . . . where comfortlevels end
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
daar was `n post op die http://www.4x4community.co.za" onclick="window.open(this.href);return false; forum so jaar trug. Hulle reken dit is die bushes wat sluit. Hul het glo al die bushes op die ratkas vervang. Kan net nie onthou was dit net die links se bushes of was dit alles nie.
Ps. my KZ doen dit ook so 3 keer n maand.
- witmamba
- Town: Sasolburg
- Real Name: Hans
"3 keer 'n maand" mmmmmmmmm...... klink vir my soos bakkie PMS!
- Gertc
Ek se niks
- RaVeN6
- Vehicle: '99 Hilux DC 3000D
- Real Name: Rudolf
hi, my bakkie het dit gedoen kort nadat ek hom gekoop het, al wat ek gedoen het is die clutch se slave cylinder op die kant van die gearbox te bloei, ry nou al meer as 'n jaar en dit het nog nie weer gebeur nie, ek sê nie dit sal werk nie, maar dis maklik en vinnig genoeg om te probeer..
- Real Name: Martin
This sounds like it might be a simple and fast solution. I'll do this on the weekend and monitor how it goes forward (s'cuz the pun...)RaVeN6 wrote:hi, my bakkie het dit gedoen kort nadat ek hom gekoop het, al wat ek gedoen het is die clutch se slave cylinder op die kant van die gearbox te bloei, ry nou al meer as 'n jaar en dit het nog nie weer gebeur nie, ek sê nie dit sal werk nie, maar dis maklik en vinnig genoeg om te probeer..
Failing that, I'll take it into the Mayfair guys to get the 'box and linkages checked out.
Thanks for the advice guys.
Regards
T
Safety 8th
