4.0 V6 Hilux Autobox Problem 4th-5th Don't change - HELP!!!!
HennieJ2
Town: Witbank
Vehicle: Hilux D/C D4D 4x4, Hilux KZ-TE D/c 4x4
Real Name: Hennie Jackson
Post by HennieJ2 »
Hi All,
My friend's Hilux has developed a serious problem with it's auto box. :shifty: It would not change from 4th gear to 5th. :o: Our local dealer's technicians are also stunned, as the diagnostic computer don't pick up any problems (no fault code). It shows all is fine , but when driving it doesn't change. :thumbdown: It's a 2005 Hilux Vigo 4.0 V6 auto 4x4.
Any advice will be appreciated. :thumbup:
Regards
Hennie
Re: 4.0 V6 Hilux Autobox Problem 4th-5th Don't change - HELP
Post by CasKru »
Is this only starting to happen now that it is winter time? Does it stay like that or does it eventually come right when the vehicle has been driven for a while?
HennieJ2
Town: Witbank
Post by HennieJ2 »
Hot / cold - remains the same. Diagnostics at dealers show no existing problem......
HJ
Post by CasKru »
When I was still at school my mom and one of my friends mom's made turns to drop us of at school. In winter time my friends mom's car would do a similar thing where it would not change gears (Ford Sierra 2.0) but once you drove it for a while and all the components heated up, it was working fine.
As I understood their problem was due to incorrect spec ATF. m2cw
warthog
Town: Barberton
Vehicle: Fortuner 4.0 V6 Auto, LRFT, Dual Batt, OME's, BFG AT's, ARM comp, 800w inv, Roofrack
Real Name: Hennie
Post by warthog »
Hennie, I also have a transmission problem on Forest, very unwilling to gear up from 5th to 4th, need to really floor the petrol to make it go up, and because of the accelaration then, goes to 3rd. Had it at Toy dealer twice already, still not completely fixed, will have to take it back again.
When I took it in first time, they couldn't find anything on the diagnostics, but some guy from Toy SA happened to be there, and he immediately told the mech's to check the ATF level in the gearbox. It's a complicated procedure where they have to bridge points on the diagnostic plug, change gears up and down few times, run the engine till it reaches a certain temp, lift the vehicle up and check the level manually by opening a plug on the gearbox.
Apparently if there's either too much or too little ATF in, it causes a problem with the hydraulics of changing gears... that how I, being quite severely technically and mechanically handicapped and disadvantages, understood it.
Hennie
Live simply, Love generously, Care deeply, Speak kindly. Leave the rest to God.
Jos 24:15: "As for me and my house, we will serve the Lord"
HennieJ2
Town: Witbank
Post by HennieJ2 »
Thanks Hennie - his problem is that it doesn't go to 5th at all - I spoke to him this morning and suggested that they check the contactors on the gear lever. If you flick the lever left, it keeps the box in 4th or rather prevents / limit it to kicks to 5th. If this switch/contactors fails to send the message to the transmission controller (hi china - road is open ek se - you can now gon into 5th if you want.....) then it will keep it in 4th. My friend uses this function a lot - especially if he is towing. This prevents the box from "rowing" between 4th and 5th, saving fuel. Maybe because of the plenty usage, the contactors are not "making" when he puts it in Drive and the TCU thinks it is still limited to 4th only.
Hennie
Liaan
Town: Lichtenburg
Vehicle: 99 2.7 DC 4x4
Real Name: Liaan
Club VHF Licence: AC1
Post by Liaan »
Hennie
Wou nou net vra of dit nie dalk die geval is nie, weet van 'n paar manne wat per ongeluk die ding in 4 vergeet en nie in D dit nie!
Groete
Liaan
Almal kry die voorreg om onnosel te wees, net jammer party maak misbruik daarvan
99 2.7 Raider 4x4 D/c
OME and some more...
Gebore in die BLOU BUL hoofstad
HennieJ2
Town: Witbank
Post by HennieJ2 »
Liaan, ja, kan nogal embarrassing wees - maar nee, hy ken die shifting procedure goed. Ek persoonlik dink daai swithc is uit gewerk.
Hennie
Post by pietpetoors »
Is nogal 'n probleem met vandag se mechanics, if the computer does not pick up anything they have no clue where to look for a problem.
HennieJ2
Town: Witbank
Post by HennieJ2 »
.... en dan wonder hulle hoekom ek se, hulle is "new part fitters" - nie mechanics nie :twisted:
Hennie
Janna
Town: Parys
Vehicle: 2007 Hilux V6 4x4
Real Name: Jan
Post by Janna »
Hi
As per discussion, has anyone came to the actual fault of why the bakkie don't change to o/d 5th gear?
I do have the same problem now ( 2007 Hiux V6 auto ) & Mark at WMJ is also struggling & pulling hair out to get it to 'kick' over on overdrive/5th?
Big Please!
Any Advice?
Jan
082 419 9919
jan.marais@flsmidth.com
HennieJ2
Town: Witbank
Post by HennieJ2 »
Still the same of many of $$$$$$$$$$ many of fights and many of moervloeke - he went to fetch his bakkie and is driving as is currently
HJ
gummi
Town: Windhoek
Vehicle: Hilux 4.0 Auto
Real Name: Michael
Post by gummi »
Hi,
I just found this post. My Hilux 4.0L auto has the same problem. It just does not want to shift to 5th gear. Computer just gives error message but no code. Went to 3 mechanics / electricians already and they are all struggling.
Has anyone ever found the fault yet?
Kind regards
Michael
dd6
Vehicle: 1995 SFA
Real Name: Jaco
Post by dd6 »
Have any of you guys changed the filter in the gearbox? Any differance afterwards?
HennieJ2
Town: Witbank
Post by HennieJ2 »
Guys, after quite some time, my friend's Lux is still not fixed - controllers ge- chane, box laar oordoen, etc, etc, etc etc. Hy het na maande sy bakkie gaan haal en ry hom nou ma so....
stumps
Town: Alberton
Vehicle: Toyota 4.0L D/C 4x4; Camil
Real Name: Marius
Club VHF Licence: X225
Post by stumps »
gummi wrote:Hi,
Kind regards
Michael
What model do you have?
2008 Hilux 4.0L 4x4 (Mufasa)
Toyota 4.0L D/C 4x4; Camil suspesion, Long Range tank, Kilber snorkel
1Co 15:10
But by the grace of God I am what I am: and his grace which was bestowed upon me was not in vain;
http://www.sandriver.co.za" onclick="window.open(this.href);return false; http://www.travelconsortium.co.za" onclick="window.open(this.href);return false;
gummi
Town: Windhoek
Real Name: Michael
Post by gummi »
Hi,
Mine is 2006 model with almost 200, 000km.
Regards
Michael
gummi
Town: Windhoek
Real Name: Michael
Post by gummi »
dd6 wrote:Have any of you guys changed the filter in the gearbox? Any differance afterwards?
Apparently the filter was changed already.
stumps
Town: Alberton
Real Name: Marius
Post by stumps »
gummi wrote:Hi,
Regards
Michael
seem like the problem lies with 2005/6 models
1Co 15:10
gummi
Town: Windhoek
Real Name: Michael
Post by gummi »
Still weird that nobody has a solution. Different forum same problem... no solution.
Does the gearbox have a separate control unit or is it's function also controlled by he ECU?
ROOKIE
Town: HILLCREST
Vehicle: 12 4.0 V6 4x4.
Real Name: PAUL
Post by ROOKIE »
Hello All. Not sure if this is of any use.
Assuming your vehilce has the A750F transmission, running through the fail safe charts the shift from 4th to 5th will be prevented with the folloing failures:-
No 1 ATF temp sensor,
A failure of shift solonoid valve SR, SL1 or SL2.
A DTC should be generated when one of these fail, so the fact that codes cannot be found is odd.
I would start by changing the ATF sensor.
09 4.0 V6 Auto 4x4.
gummi
Town: Windhoek
Real Name: Michael
Post by gummi »
Thank you for the advice.
I have got it at a different mechanic now. He also has the diagnostic computer. Maybe he can put it on again and then see if there is a code.
Will let you know.
Kind regards
Michael
kornis_istvan
Town: Cristur - Romania
Vehicle: LC 120
Real Name: KORNIS
Post by kornis_istvan »
Hy everybody!
It is my first time when I wrote in your forum.I am from Europe but I think I can help you and i found a lot of interesting information here.
I am Toyota Master Technician.
i have today solved this problem on LC 120 engine 1kd A750f Transmission when the transmission wont change 4th to 5th . For more information give me the VIN of your vehicle to help you.
Sorry for my bad english...
Ali3n
Club VHF Licence: B338
Post by Ali3n »
kornis_istvan wrote:Hy everybody!
Hi and welcome Kornis. :thumbup:
PRESENTLY DISADVANTAGED
gummi
Town: Windhoek
Real Name: Michael
Post by gummi »
Hi Kornis,
thank you for your post. Your English is not bad.
I already sent you my VIN via Email. It would be great if there would finally be a solution.
Thank you
Mars67
Vehicle: Hilux 3.0 D4D DC 4X4
Post by Mars67 »
Welcome Cornis.
It would be great to know what the solution is.
kornis_istvan
Vehicle: LC 120
Real Name: KORNIS
To help you I need the VIN and the description of defection.have you or haven't DTC. Has sombody check the transmission and SR and SL1 solenoids or not?Is jerking when change N to D?Is very important detail to find final the solution.In Eastern Europe We are repairing models with diesel engine but the metode of reparation is not different from gasoline engines.
Eicker
Town: Witbank
Vehicle: Hilux 4.0L V6 Auto 4x4 / 2005
Post by Eicker »
Hi Guys
I thought I'll join the discussion as the original post in 2010 was about my Hilux. Just to let you know that my problem has not been resolved yet.
Just a quick overview of what was done to my Hilux over the years:
- Replaced complete gear shift unit, (P,N,D unit)
- Replaced water temp. sensor
- Removed all four catalytic converters and changed exhaust system with free-flow one
- Replaced all four O2 sensors on the exhaust
- Replaced main ECU computer
- Replaced fuel pump. (Had to)
- Had the gearbox at three different gearbox outlets, every time they changed solenoids and clutches. But this did not solve my problem.
- Even put a chip in to see if that will help. Noooo!
Hope this will help to eliminate a few scenarios for you guys cause I do not have many left.
Can the guys please let me know if the gear shift problem is the only one, or are there any other problems that came with that.
As in my case, my Hilux also short shift in first ,second and third gears. Only goes max 3500rpm before shifting.
Only fourth gear goes over 3500rpm or if I lock it manually in the other gears.
kornis_istvan
Vehicle: LC 120
Real Name: KORNIS
It is possible to make a snapshot with original diagnostic tool?
It is very important to decide the engine Ecu command the solenoids to shift 5th gear or not.
If the ecu not command the solenoids SL1 and SR you have problem with input signals.If the ecu command the Solenoids you may have problem with Ecu Or solenoids.
Eicker
Town: Witbank
Post by Eicker »
Thanks Kornis, this makes a lot of sense.
I will do a diagnostic test early in the new year on the ECU to see whether the ECU send out the commands to the solenoids or not. This way I can eliminate a lot of probabilities.
It would be nice to know if the problem is in the gearbox or if it is some sensor malfunction.
kornis_istvan
Vehicle: LC 120
Real Name: KORNIS
Eicker wrote:Thanks Kornis, this makes a lot of sense.
Before diagnosis i will send you the wiring diagram and terminals of ecu of your car.It is important to know two important things :
The 5th gear is commanded only electronic by solenoids.If you make test drive with solenoid wire disconnected the transmission gear will change all gear except 5TH.
The tester never show you if the solenoid SL1 an SR is commanded or not,only show the SLU and SLT.You should measuring the signal of this solenoids.They have different signal, and the Sl1 only with oscilloscope could be measured.
To help you , make a registration with IT2 tester and send for me the snapshot, after this i try to give you some advice how to eliminate the defective parts.
carlo4e
Town: Groblersdal
Vehicle: Hilux V6
Real Name: Carlo
Post by carlo4e »
Hi Chris. I also drive a V6, 2006 model. Don't have the problem but would love to know the solution (if it happens). Touch wood...
私のハイラックスが大好きです
kornis_istvan
Vehicle: LC 120
Real Name: KORNIS
Hy,
are you solved this problem?
Philly
Town: Jhb
Vehicle: 2014 Toyota Prado VX D4D
Real Name: Phillip
Post by Philly »
Hi Chris.
Any news on you problem, I also drive a 4l v6 auto and would like to hear if you found the solution yet? Just in case mine starts (hope is never does, but you never know)
Eicker
Town: Witbank
Post by Eicker »
Hi Guys
The problem is still not solved yet. I must admit, I did not spend any time finding the problem this year so far. I guess I am a bid tired of people working on my Hilux and keeping it in a workshop for weeks or months at a time. I am just frustrated at the moment.
I am driving the Hilux as is at the moment, maybe I will try again later this year to get it fixed.
I will let you guys know if and when I get the problem fixed. :surrender:
gummi
Town: Windhoek
Real Name: Michael
Post by gummi »
Hi All,
We had our vehicle at a mechanic today. He noticed that the speed signal from the gearbox only shows about half the true speed.
That could be the reason why it's not shifting up.
Now we have to find out why its only showing half the true Value if corrected will solve the problem.
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Gummi easy fix... drive twice the speed! :mrgreen:
Ali3n
Post by Ali3n »
I don't know if it is the same problem but I had a problem where my vehicle would not change from 3rd to 4th. (4speed auto) After process of eliminatio, replacing solenoids, valve body, checking wiring, checking ecu and so on if found that my box had 2 speed sensors. front one controlled the shifting 1st, 2nd and 3rd and the back one would control 3rd to 4th/overdrive. checked the resistance on the 2 speed sensors and the back one was dead. Replaced it and voila, perfect. :thumbup:
gummi
Town: Windhoek
Real Name: Michael
Post by gummi »
Hi Everybody,
my Hilux has got its 5th gear again. :yahoo:
The mechanics from Caspers Car Repair Centre in Omaruru found and fixed the problem together with Kornis.
It was the low gear switch in the gear box that was broken as far as I understand.
Thanks to you guys for the help and effort ,
Regards
Gummi
stumps
Town: Alberton
Real Name: Marius
Post by stumps »
[DANCER][DANCER][DANCER][DANCER][DANCER][DANCER][DANCER][DANCER][DANCER]
1Co 15:10
mossie89
Town: Paarl
Vehicle: Toyota Hilux D/C 4x4 4.0 v6
Real Name: Riaan
Post by mossie89 »
Please keep us up to date if the problem was solved :subscribed:
gummi
Town: Windhoek
Real Name: Michael
Post by gummi »
Hi Mossie.
The Problem is solved.
Regards
Michael
andrey_key
Town: Moscow
Vehicle: LC 120
Real Name: Andrey
Post by andrey_key »
good day, have a car Land Cruiser Prado 3.0 D4D (4x4) A750F, the problem in shifting from 4 to 5 techstream shows the movement of the vehicle 5 transmission and 4, auto repair can not help, no error codes dismantled all together gathered the problem persists, tell me what could be?
andrey_key
Town: Moscow
Vehicle: LC 120
Real Name: Andrey
says the problem is solved, tell me where to look? sorry for my english, Google translator :slap:
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Andrey...
The post says:
"It was the low gear switch in the gear box that was broken as far as I understand. "
Hope that helps!
andrey_key
Town: Moscow
Vehicle: LC 120
Real Name: Andrey
Bretton it I realized, thanks, I wanted to know exactly!
Phillip3000
Town: Biloela
Real Name: Phillip
Re: 4.0 V6 Hilux Autobox Problem 4th-5th Don't change - HELP!!!!
Post by Phillip3000 »
Hi have a 2005 V6 4.0 having problems changing from 4th to 5th does so after around 6seconds up hills n overtaking drives good around town or highway found out only under pressure it plays up help needed has 250 on clock have done full gearbox service n has been put on a scan from the transmission auto place no codes came up karnt find a solution they said might want to do a rebuild any advice b great b4 i get a recondition box cheers
Phillip3000
Town: Biloela
Real Name: Phillip
Phillip3000 wrote: Fri Jun 10, 2022 2:23 am Hi have a 2005 V6 4.0 having problems changing from 4th to 5th does so after around 6seconds up hills n overtaking drives good around town or highway found out only under pressure it plays up help needed has 250 on clock have done full gearbox service n has been put on a scan from the transmission auto place no codes came up karnt find a solution they said might want to do a rebuild any advice b great b4 i get a recondition box cheers
kornis_istvan wrote: Wed Dec 18, 2013 8:49 pm Hy everybody!
