Antenna mounting
scott west
Vehicle: 93 Hilux
Real Name: Z
Club VHF Licence: HC 117
Will it be possible to mount a Zara60, that requires a 19mm hole, into a 21mm hole.
The reason i' am asking is, I want to mount the antenna into the original radio's antenna hole. (Not using the sound system).
Thanks.
Z.
'93 Hilux 4Y EFI
Hilux 1
Real Name: Tertius
Club VHF Licence: HC137
you'll need to put a reducer ring.
scott west
Vehicle: 93 Hilux
Real Name: Z
Hilux 1 wrote:you'll need to put a reducer ring.
Thanks for the reply, will get one when buying the radio. I am sure our Family dog will be able to help me.
Z.
'93 Hilux 4Y EFI
Hilux 1
Real Name: Tertius
jip, sure he'll be able to
zepplin
Vehicle: Crooza VX 80 EFI
Real Name: Steve
Club VHF Licence: HC 127
Just use a stainless washer of suitable size.
Scott, you can use either a 19mm or a 20mm hole saw. You would have to try it with the (existing?) 21mm hole, chances are that might be a bit shaky. 19mm is a tight fit but the system is designed for that, 20mm works fine but 21mm is something we've never tried - all our hole saws are 19mm. Although it might fit, it might work loose during travelling with the excess movement.
Where is the existing hole - on the fender?
Repcom Mobile Antennas – Installation Instructions.pdf
(97.36 KiB) Downloaded 48 times
scott west
Vehicle: 93 Hilux
Real Name: Z
Family_Dog wrote:Scott, you can use either a 19mm or a 20mm hole saw. You would have to try it with the (existing?) 21mm hole, chances are that might be a bit shaky. 19mm is a tight fit but the system is designed for that, 20mm works fine but 21mm is something we've never tried - all our hole saws are 19mm. Although it might fit, it might work loose during travelling with the excess movement.
It's a Jeep Wrangler, on the side of the body. It seems that drilling a 19mm hole is the only way to go.
Z.
'93 Hilux 4Y EFI
Return to “Radios and Licensing”
