1000 or above lumen bike LED light
Do you prefer to 2 wheels to 4? Share your photographs and cycling stories here
Niel
Real Name: Niel
Post by Niel »
I am looking at investing in a LED cycle light – will be used off road mostly. Any one that can recommend a decent above 1000 lumen or above light – I have seen 4x4 direct option but they have no stock. Pls indicate the lumen en price (if possible) and where I can obtain it from.
Town: inniedorp
Vehicle: Toy
Re: 1000 or above lumen bike LED light
Post by ChrisF »
Nitekor ??
Niel
Real Name: Niel
Post by Niel »
Dankie Chris, het al gekyk na hulle maar die T 11, 15 en T26 is in die range maar ek dink nie die bike clip sal daarop werk nie en die spaarvarkie moet verkieslik ook heel bly. Daai T 26 is die heeltyd in my agterkop want daai is n awsome lig.
Stubs
Town: Onrusrivier Hermanus
Vehicle: 89, Hilux D/cab 3.0L V6 Ford !!
Real Name: Stuart
Post by Stubs »
Hi Neil, I will have stock very shortly, its stuck at customs.......very nice light it is BTW......
Niel
Real Name: Niel
Post by Niel »
Stubs, Thanks. is it the 1000 lumen one or something a bit stronger?
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
Stuart vertel so bietjie meer oor jul ligte asseblief.
Stubs
Real Name: Stuart
Post by Stubs »
hi guys check the links below for the lights, specifically designed for Cycling come with the clips etc etc
http://www.4x4direct.co.za/shop/led-bik ... -p-120.htm" onclick="window.open(this.href);return false;
http://www.4x4direct.co.za/shop/led-bik ... p-p-99.htm" onclick="window.open(this.href);return false;
cheers Stubs
Niel
Real Name: Niel
Post by Niel »
I know of the second one (1800 l) what is the dimensions of the light as there are not a lot of space on the handle bar and what is the weight and length of the power cable pls if you don't mind.I see the battery pack is separate from the light and do you have the dimensions pls
Stubs
Real Name: Stuart
Post by Stubs »
Hi Neil,
ok 90mm across, 55mm from base of clamp to top of light, 60mm deep,
battery pack is 80mm wide, 65mm deep, 80mm high,
The battery pack weighs 300 grams and the light weighs 225 grams
Hope this helps
cheers
Stubs
Niel
Real Name: Niel
Post by Niel »
will check the available space on the handle bar. Thanks
Niel
Real Name: Niel
Post by Niel »
Stubs thanks for the detail but it is a bit to big and got hold of a 2600 l - very small 40mm wide and 45 h. for a very good price.
Return to “Cycling and Mountain Biking”
