Age profile of SFA forum
- Town: Howick
- Vehicle: 1998 Hi-lux 2,4 S/cab (p); 1997 Hi-lux 2,4 D/cab (p)
- Real Name: Harold
Seems like the 'ou toppies' are neck-and-neck wth the young 'okes' - maar vir hoe lank?
Harold (Greytown, KZN)
Depends ..... what age you perceive as being "ou toppies".Harold wrote:Seems like the 'ou toppies' are neck-and-neck wth the young 'okes' - maar vir hoe lank?
- NathanX4
- Town: Meyerton
- Vehicle: 1991 Toyota Hilux (Ford powered 2.5TD) 4X4
- Real Name: Nathan
Daar is net 2 young 'okes'?Harold wrote:Seems like the 'ou toppies' are neck-and-neck wth the young 'okes' - maar vir hoe lank?
- Tarquin
- Town: Plettenberg Bay
- Real Name: Tarquin
3
I always thought the SFA was more of a young okes vehicle... something fairly cheap and rough that one doesn't have to take too much care if you scratch it or not!
- Baasvark
- Town: Virginia
- Real Name: Shane
Could also be that the "older" generation keep it as a toy and not primary/secondary vehicle....
At least that is what I do....
- ôita
- Town: Piet Retief
- Vehicle: 1994 Toyota Hilux D/cab 4x4 SFA, 2.7 conversion,TrailGear Duel Transfercase with 4.7gear,Front & rear Difflocks,50mm body lift,Procomp & Mikem Suspention,Snorkel,L/R fuel tank, 32" M/T tyres, my son in the passenger seat
- Real Name: Kobus
Die jonges wil en die oues kan....Leke om te sien die jonges speel met die ou "tried and tested"
"Stronger than a New Zealand Kauri tree and, as we found out, virtually indestructible, the Hilux is an unapologetically manly car." - Top Gear Verdict
Perhaps, but my lux could almost be called a daily runner. If the early results of this poll can be considered, you will see that there is a definite drop off after about 50 yrs, probably mainly because of the comfort issue and perhaps also because of the probable maintenance issues being anticipated with older vehicles.Baasvark wrote:Could also be that the "older" generation keep it as a toy and not primary/secondary vehicle....
- ôita
- Town: Piet Retief
- Real Name: Kobus
I use mine daily to work and back while SWAMBO uses the Pajerosport. Both capable depends on what the needs are on the day...distance to be traveled always have the say
- Tarquin
True that!ôita wrote:Die jonges wil en die oues kan....Leke om te sien die jonges speel met die ou "tried and tested"
Myne is also not a daily runner, more of a weekendly runner
- ôita
- Town: Piet Retief
- Real Name: Kobus
dd6 wrote:Not many 75+ people are computer savvy enough to be able to vote in the pole!
Very very true
- swartvark
- Town: Gordons Bay
- Real Name: Tiaan
Die SFA bly maar die mooiste en taaiste trok.
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
Klaar gestem , Oom Chris! 25+ jaar.
F_D,
Careflully tapped from my iPad using Tap-tap-Tapatalk
F_D,
- Vehicle: 1)1989 Toyota Hilux 2.2 4y EFI D/C 4X4 Full Mikem suspension ,extra long range tank,Duel battery system,31 Bridgestone Duelers 697 A\T FJ 75 front disc with KZTE calipers ,Kurisun PT 8100 two way mobile radio Hi-Lux call sign HC 121
- Club VHF Licence: X93-
My vote gedoen
