Cancer Update from Johns Hopkins:
1. Every person has cancer cells in the body. These cancer
cells do not show up in the standard tests until they have
multiplied to a few billion. When doctors tell cancer patients
that there are no more cancer cells in their bodies after
treatment, it just means the tests are unable to detect the
cancer cells because they have not reached the detectable
size.
2. Cancer cells occur between 6 to more than 10 times in a
person's lifetime.
3. When the person's immune system is strong the cancer
cells will be destroyed and prevented from multiplying and
forming tumours.
4. When a person has cancer it indicates the person has
nutritional deficiencies. These could be due to genetic,
but also to environmental, food and lifestyle factors.
5. To overcome the multiple nutritional deficiencies, changing
diet to eat more adequately and healthy, 4-5 times/day
and by including supplements will strengthen the immune system.
6. Chemotherapy involves poisoning the rapidly-growing
cancer cells and also destroys rapidly-growing healthy cells
in the bone marrow, gastrointestinal tract etc, and can
cause organ damage, like liver, kidneys, heart, lungs etc.
7. Radiation while destroying cancer cells also burns, scars
and damages healthy cells, tissues and organs.
8. Initial treatment with chemotherapy and radiation will often
reduce tumour size.
However prolonged use of chemotherapy and radiation do not result in more tumour destruction.
9. When the body has too much toxic burden from chemotherapy and
radiation the immune system is either compromised or destroyed, hence the person can succumb to various kinds of infections and complications.
10. Chemotherapy and radiation can cause cancer cells to
mutate and become resistant and difficult to destroy.
Surgery can also cause cancer cells to spread to other sites.
11. An effective way to battle cancer is to starve the cancer
cells by not feeding it with the foods it needs to multiply.
*CANCER CELLS FEED ON:
a. Sugar substitutes like NutraSweet, Equal, Spoonful, etc are made
with Aspartame and it is harmful. A better natural substitute
would be Manuka honey or molasses, but only in very small
amounts. Table salt has a chemical added to make it white in
colour Better alternative is Bragg's aminos or sea salt.
b. Milk causes the body to produce mucus, especially in the
gastrointestinal tract. Cancer feeds on mucus. By cutting off milk and substituting with unsweetened soy milk cancer cells are being starved.
c. Cancer cells thrive in an acid environment. A meat-based
diet is acidic and it is best to eat fish, and a little other meat,
like chicken. Meat also contains livestock antibiotics, growth hormones and parasites, which are all harmful, especially to people with cancer.
d. A diet made of 80% fresh vegetables and juice, whole
grains, seeds, nuts and a little fruits help put the body into
an alkaline environment. About 20% can be from cooked
food including beans. Fresh vegetable juices provide live
enzymes that are easily absorbed and reach down to
cellular levels within 15 minutes to nourish and enhance
growth of healthy cells. To obtain live enzymes for building
healthy cells try and drink fresh vegetable juice (most
vegetables including be an sprouts) and eat some raw
vegetables 2 or 3 times a day. Enzymes are destroyed at
temperatures of 104 degrees F (40 degrees C)..
e. Avoid coffee, tea, and chocolate, which have high caffeine Green tea is a better alternative and has cancer fighting properties. Water-best to drink purified water, or filtered, to avoid known toxins and heavy metals in tap
water. Distilled water is acidic, avoid it.
12. Meat protein is difficult to digest and requires a lot of
digestive enzymes. Undigested meat remaining in the
intestines becomes putrefied and leads to more toxic build-up.
13. Cancer cell walls have a tough protein covering. By
refraining from or eating less meat it frees more enzymes
to attack the protein walls of cancer cells and allows the
body's killer cells to destroy the cancer cells.
14. Some supplements build up the immune system
(IP6, Flor-ssence, Essiac, anti-oxidants, vitamins, minerals,
EFAs etc.) to enable the bodies own killer cells to destroy
cancer cells.. Other supplements like vitamin E are known
to cause apotheosis, or programmed cell death, the body's
normal method of disposing of damaged, unwanted, or
unneeded cells.
15. Cancer is a disease of the mind, body, and spirit.
A proactive and positive spirit will help the cancer warrior
be a survivor. Anger, un-forgiveness and bitterness put
the body into a stressful and acidic environment. Learn to
have a loving and forgiving spirit. Learn to relax and enjoy life.
16. Cancer cells cannot thrive in an oxygenated
environment. Exercising daily, and deep breathing help to
get more oxygen down to the cellular level. Oxygen therapy is another means employed to destroy cancer cells.
1. No plastic containers in micro.
2. No water bottles in freezer.
3. No plastic wrap in microwave..
Johns Hopkins has recently sent this out in its newsletters. This information is being circulated at Walter Reed Army Medical Centre as well. Dioxin chemicals cause cancer, especially breast cancer. Dioxins are highly poisonous to the cells of our bodies. Don't freeze your plastic bottles with water in them as this releases dioxins from the plastic. Recently, Dr Edward Fujimoto, Wellness Program Manager at Castle Hospital , was on a TV program to explain this health hazard. He talked about dioxins and how bad they are for us. He said that we should not be heating our food in the microwave using plastic containers. This especially applies to foods that contain fat. He said that the combination of fat, high heat, and plastics releases dioxin into the food and ultimately into the cells of the body. Instead, he recommends using glass, such as Corning Ware, Pyrex or ceramic containers for heating food. You get the same results, only without the dioxin. So such things as TV dinners, instant ramen and soups, etc., should be removed from the container and heated in something else. Paper isn't bad but you don't know what is in the paper. It's just safer to use tempered glass, Corning Ware, etc. He reminded us that a while ago some of the fast food restaurants moved away from the foam containers to paper The dioxin problem is one of the reasons.
Also, he pointed out that plastic wrap, such as Saran, is just as dangerous when placed over foods to be cooked in the microwave. As the food is nuked, the high heat causes poisonous toxins to actually melt out of the plastic wrap and drip into the food. Cover food with a paper towel instead.
Health tips
Health tips
- Theodorus
- Town: Honeydew Jhb
- Vehicle: HILUX
- Real Name: Theo
Health tips
Om vleis te los is maar moeilik
I am here: http://maps.google.com/maps?ll=-26.068465,27.967163" onclick="window.open(this.href);return false;
Re: Health tips
Not really ... you can start by replacing some of your main meals with a fish or chicken dish (there are thousands of tasty recipes out there). Additionally you can choose leaner cuts of meat and venison is also a healthy alternative. Then you can also counteract the acidity with the correct balance of vegetables. It's not such a big thing .... just a few small adjustments.Theodorus wrote:Om vleis te los is maar moeilik
