Battery charge monitor
hatvani
Town: Dar es Salaam
Vehicle: 2002 Toyota Hilux 2.5TD D4D. 4" lift with 32x11.5x15 tires, A-bar, Hannibal roof rack with Eezy Awn tent..
Real Name: Tom
Post by hatvani »
I have 2 batteries 750 mA each parallel connected (it is a UK model Hilux and standard). I would like to install a battery charge monitor, but most go up to only 650 mA. If I understand it right the two together are 1,500mA. Any suggestions? I really don't feel like separating the 2 batteries.
Thanks.
Gertc
Vehicle: 3.0L Fortuner
Real Name: Gert Combrink
Club VHF Licence: Xray05
Re: Battery charge monitor
Post by Gertc »
750mA sounds like AA batteries?
hatvani
Town: Dar es Salaam
Real Name: Tom
Post by hatvani »
Do you have an answer if you take away the "m" or you're just more like a funny guy? :think:
tersmit
Town: Durbanville Cape Town
Vehicle: '06 Hilux 4x4 4.0 Auto D/C, 185a/h Dual Battery Sistem, 1500w inverter
Real Name: Tertius
Post by tersmit »
Hi Tom
Do you not maybe mean 75Ah batteries ?
i.e. more or the the same physical dimensions than a regular car battery
Hilux 1
Vehicle: 2011 Raider 4x4 Double cab 4.0 V6
Real Name: Tertius
Club VHF Licence: HC137
Post by Hilux 1 »
Hi Tom,
have you tried a local auto electrician? maybe they have or can import a National Luna type monitor? m2cw
Gertc
Post by Gertc »
why do you want to monitor the Amps? Why don`t you just monitor the voltage? If you want to monitor 1500Amp you will have to look at a shunt resistor that has been calibrated with a panel meter. and the only time you will use that amps is with a winch that is close to burning out. When charging you should not go higher than 70Amp. or what ever your alternator can deliver. most of the battery monitors just measures the voltage 10.8Volt is flat and 13.8Volt is fully charged
