4y running on two cylinders
Posted: Wed Dec 20, 2023 12:20 pm
So my 4y decided it wants to give me bollie....
Started with some splittering and hesitation and grew to what it is now....
It seems it is running only on cylinder 3 and 4.
I have replaced: distributor cap, leads, plugs, rotor.
I even had a Chinese carb on here before it happened since the float in the original fell apart.
Timing has not been changed, all vacuum pipes are correct.
Took the new plugs out, 3 and 4 are dark black with 1 and 2 still clean.
There is spark for all plugs and strong too.
I am now at wits end.
Took the cover off, rockers are rocking and valves seem to be opening. No noise from lifters or any engine noise.
Any thoughts or suggestions?
Sent from my SM-G998B using Tapatalk
