2.7i Question
- Town: Camperdown
- Vehicle: 99 Hilux 4x4 DC
- Real Name: Roger
2.7i Question
Morning all
So I bought a 1999 4x4 DC 2.7i Hilux 2 months ago.
385k km on the clock, motor seems fine, no noise, smoke etc.
Van has branch, and freeflow front box, and I had freeflow rear box fitted a couple of weeks ago.
Generally happy with the ride, however went to the Berg on the weekend, and seems very underpowered
on the hills, eg. Lundy's Hill, is a long pull back towards PMB from the Umkomaas valley.
Had to change down to 3rd, and dropped speed down to about 70, IIRC..
Is this normal, or does it need attention?
If it's normal, is there anything, short of engine conversion, that I can do at a reasonable cost to improve it?
Thanks in advance!
Thanks in advance!
- niclemaitre
- Town: Stellenbosch
- Vehicle: 99 IFS DC 4x4
- Real Name: Nic
Re: 2.7i Question
Sounds similar to mine, and yes it does lack some top end power. Try to keep the revs higher than 3200 rpm. If you drop below that, you'll struggle. I think the altitude affects it too.
The Vigo Hiluxes came with a VVTi version that performs better. I don't know if it's possible to add the VVTi to the 3RZ block (I presume its the same) but you'd need the ECU and harness too.
Happy trails
Nic
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
Nic
IFS '99 DC "Benny"
Re: 2.7i Question
That is normal and was made worse by removing or free flowing the very first box in the exhaust. That first box helps with a bit of torque. But the 2.7 do not like hills and it do not like towing. Is always a battle, dies in 4th and when you go to 3rd it over rev. Gap between 4th and 3rd too big.
Only gets alive over about 3500 rpm.
Re: 2.7i Question
Many moons ago when mine still had a 2.7 in, I also wanted to remove the first box. Both Hoppy and PowerFlow exhaust in CPT told me not to do it because I will loose torque. They also said the std branches it came from factory is good enough, they cannot improve it. If a company like PowerFlow loose a job due to their honest advice I tend to believe them.
- Town: Camperdown
- Real Name: Roger
Re: 2.7i Question
Thanks Nicniclemaitre wrote: ↑Thu Mar 23, 2023 8:36 am Sounds similar to mine, and yes it does lack some top end power. Try to keep the revs higher than 3200 rpm. If you drop below that, you'll struggle. I think the altitude affects it too.
- Town: Camperdown
- Real Name: Roger
Re: 2.7i Question
Thanks Pietpietpetoors wrote: ↑Thu Mar 23, 2023 9:28 am Many moons ago when mine still had a 2.7 in, I also wanted to remove the first box. Both Hoppy and PowerFlow exhaust in CPT told me not to do it because I will loose torque. They also said the std branches it came from factory is good enough, they cannot improve it. If a company like PowerFlow loose a job due to their honest advice I tend to believe them.
The new freeflow rear that I put in is stainless steel. the rest of the system mild. I replaced the rear cos it had a crack in it, with the intention of replacing the mild with SS as necessary. If I change the first box to standard, do you think there would be any effect?
Re: 2.7i Question
As long as there is still a first box it should be fine. Some people remove the first box completely which is not good. I also have SS freeflow at back.
- Town: Harkerville WC
- Vehicle: 1990 Hilux 4Y
- Real Name: Peter
Re: 2.7i Question
Does this logic apply to the 4Y as well? Many years ago my front box developed a leak, so I removed it. A year or so later the middle box got a leak, removed that too, so am now running with just the last box. Performance didn't seem to change with each removal (but then 4Y and performance is a bit of an oxymoron)
Re: 2.7i Question
I never owned a 4y long enough to gain experience on it.
I am sure there are long time 4y owners who can tell you better.
I know in the performance world there is a thing that the engine must always be able to breathe properly. That is true for an engine that is running at high revs.
Anything you use at low or normal rpm needs back pressure for better torque. The question is just how much back pressure.
Re: 2.7i Question
My 4Y still has the original exhaust system fitted but I also did an EFI conversion as documented elsewhere on this forum. All I can say regarding the EFI Conversion is: "WOW!!"
Power and pleasure has increased by an estimated 15% and fuel consumption probably is better than the standard Nikki Card but Oh, what a difference in driving pleasure. Previously where I had to change down to 3rd or 4th is no longer a problem, torque has increased tremendously.
Despite several offers from people wishing to buy Bulldog from me, I simply gently smile and change the subject. I love that SFA and will never sell her!
Here she is just after having a shower:
- Real Name: Peter
Re: 2.7i Question
If only I had the money............EFI would be done immediately. Other than that, mine is running beautifully. Love the change to 31" tyres done a few weeks ago. Seems to suit the gearing a lot better, and, I'm not sure yet, but think consumption has improved.
Apologies for hijacking the thread
Re: 2.7i Question
I run 31" tyres too, wise decision! The speedo reading now is also spot-on according to the GPS.
- Real Name: Peter
Re: 2.7i Question
Mine is still slightly out, GPS 97 speedo 100, which is spot on enough for me and gives me a slight margin for error. With the 30" tyres I was doing 100 on the GPS and 110 on the speedo
