To add to my question about PWM controllers and 7Ah batteries, another question:
Has anyone successfully added a combination Volt/Ampere meter to their solar charge setup?
I'm considering getting one of these
and build it into one of these
then make a cable using this
to connect the battery buddy to my charge controller.
Any flaws or caveats on my design?
PS. Thanks to https://www.lumenoled.co.za/ and https://4x4direct.co.za/ for the use of your images.
Volt/Amp meter on 12v charging system
- oxydog
- Real Name: Jarus
- Club VHF Licence: J67
Bees (Toy)
'98 Hilux 2.8D 4X4 D/Cab
• ARB Bullbar
• Safari Snorkel
• GearMax Rear Locker
• Front Runner bakkie slide
• 31" BFG KM2's
'06 Hilux 4.0 V6 4X4 D/Cab
• Level-it kit (Front)
• Custom integrated bullbar
• Custom replacement bumper
• Midas driving lights
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
Re: Volt/Amp meter on 12v charging system
I think Pieter sells this type of thing at 4x4 Direct...
- oxydog
- Real Name: Jarus
Correct, that's why I thanked him in my post for the use of their images!Family_Dog wrote: ↑Wed Oct 26, 2022 3:37 pm I think Pieter sells this type of thing at 4x4 Direct...
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- pietdevs
- Town: Mosselbay
I have installed the identical Amp/volt meters on my system. If you keep it on it will drain you battery within a week. The LED screen consumes a significant amount of power during 24 hrs. I verified this by checking the mA drawn by the meters from the battery and found that this is the main reason why my batteries ran down within 10 days without any external load. Wire it so that you have a little button switch so that you only check it when you want to know the Volts/Amps.
- oxydog
- Real Name: Jarus
Thanks Pieter, that makes sense! My idea was to only plug it in when I wanted to read the values.pietdevs wrote: ↑Mon Oct 30, 2023 10:38 am I have installed the identical Amp/volt meters on my system. If you keep it on it will drain you battery within a week. The LED screen consumes a significant amount of power during 24 hrs. I verified this by checking the mA drawn by the meters from the battery and found that this is the main reason why my batteries ran down within 10 days without any external load. Wire it so that you have a little button switch so that you only check it when you want to know the Volts/Amps.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
